585,748 active members*
3,563 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Broaching with Hexalobular Rotary Broaches
    Mar 2013
    18
    I need to broach a T25 hexalob anyone have any experience with this. From what I read it seems as though it can be difficult. I will be able to cheat a little on my hole size material is 1144. I will be running 1000's of parts will the broaching not be an issue or should I consider milling it. Machine is a Citizens A20 will be broaching on the main spindle
    Feb 2011
    353
    Re: Broaching with Hexalobular Rotary Broaches
    I haven't done any hexalob's just regular hex's a lot of them in 4140 with no problem
    Genswiss might be able to help with broaches and drill size and rpm for you
    Apr 2009
    1262
    You may also want to check with Slater. They do rotary broaching and have a lot of experience.
    Internal Rotary Broaches | Slater Tools, Your Source for Rotary Broaching and Screw Machine Tools
    Experience is what you get just after you needed it.
    Jul 2008
    71
    Also check out Polygon Solutions. They make some nice Swiss sized holders! Very helpful as well. Make sure your Toolpost, or GDF block is centered really close! ----------------- John :cheers:
  1. rotary broaching swiss
    By elsanch in forum MetalWork Discussion
    Last Post: 09-30-2019, 08:53 PM
  2. Rotary broaching on a budget!
    By Memran in forum Benchtop Machines
    Last Post: 02-09-2014, 05:58 PM
  3. Rotary Broaching
    By rhino in forum MetalWork Discussion
    Last Post: 09-16-2011, 07:15 PM
  4. Rotary Broaching
    By inertialabs in forum Haas Mills
    Last Post: 12-25-2010, 04:45 PM
  5. Replies: 0
    Last Post: 11-09-2007, 11:25 PM
