585,762 active members*
4,233 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Huanyang 2.2kw VFD error code E.oU.5 or EoUS or EoU5
    Nov 2013
    12
    VFD & Spindle working great for months. Several jobs cut yesterday. Power up this morning, and just get error code E.oU.S or E.oU.5
    Anyone seen this. It is similar to an error code in manual, but the manuals are generally inaccurate, and of little use.
    Replaced VFD with a spare, and all is good again. This one is probably a throw away, but thought it's worth asking for info.
    15362
    Re: Huanyang 2.2kw VFD error code E.oU.5 or EoUS or EoU5
    Quote Originally Posted by Ozzwinkle View Post
    Yes it is quit common when the Drive has not been programed or wired correct, mostly to do with voltage and how it was shut down, but can be more than one problem that can cause this problem, single phase is hard on a VFD being used like this so everything has to be correct for it to survive for a long service life
    Mactec54
    15362
    So the same thing could happen again if you have not changed anything, need to know how you have everything wired and what Parameters you have set
    Mactec54
  1. Huanyang VFD Over Current Error EoCA
    By nates02gt in forum Spindles / VFD
    Last Post: 06-18-2023, 04:01 PM
  2. Error codes for SCM Record 310 NT Router Error code 075-MACHINE OFF
    By GVANZ in forum Complaints and Praise Discussions
    Last Post: 05-28-2019, 08:30 AM
  3. . Huanyang vfd e.ou.n fault code
    By Cncmachine2 in forum Spindles / VFD
    Last Post: 06-20-2018, 02:26 PM
  4. Huanyang VFD Inverter all available Error Codes
    By Saintstone in forum Phase Converters
    Last Post: 07-08-2017, 11:26 AM
  5. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
