585,758 active members*
4,456 visitors online*
Results 1 to 6 of 6
    Dec 2014
    35
    UC300 ETH-UB1
    Hello Gents
    I am trying to connect the NPN type proximity sensors to the X,Y and Z axis.
    These NPN sensors operate from 6 V to 36 VDC.
    I was informed that these sensors can be connected to both the high 24V and the low 5V?
    If I power the sensor up with 24V and activate the sensor, by moving a metal object, to the contact point, the voltage drops to 0,8 V.
    The schematic, which comes with and on the sensor, shows a resistor between the black and brown wires. I remember doing this on my MACH3 BOB and had to achieve around 5 V, when the sensor was activated. This was also with a 24VDC supply.
    I`m just confused on how to connect it to both the 24V and 5V? This does not make sense to me and then a resistor can not be used at all, between the BLK and BRN wires.
    Regards
    Craig
    Dec 2014
    35
    Re: UC300 ETH-UB1
    I forgot to mention that these sensors are NO and not NC.
    Regards
    Craig
    Re: UC300 ETH-UB1
    11a on Page 13 of the UB1 manual
    Dec 2014
    35
    Re: UC300 ETH-UB1
    Hello Gerry
    Yes, I did see that in the schematic, but I was not sure about the resistor, which goes between the BRN and BLK wires on the sensor? I was under the impression that a resister is compulsory, or else the BOB will be damaged?
    So If I power the sensor from my 24 V PSU and connect the BRN wire to POSITIVE, then the BLK wire must go to one of the X103 - X115 inputs and the BLU wire must go to the 0 V terminal on the BOB?
    Thank you for responding.
    Regards
    Craig
    Re: UC300 ETH-UB1
    It only shows a resistor if using PNP sensors on an NPN input.
    The schematic in the manual shows brown to PS 24V, black to X103-X115 (or X210-X215), and blue to 0V on the UB1.
    I'm far from an electronics expert, so can't offer any more than that.
    Dec 2014
    35
    Re: UC300 ETH-UB1
    Thanks Gerry
    I will connect them like that.
    Regards
    Craig
  1. UC300 ETH-UB1
    By craig00747 in forum Stepper Motors / Drives
    Last Post: 05-09-2020, 08:30 PM
  2. UB1 - UC300-ETH - UCCNC not dancing yet
    By rcmcdee in forum UCCNC Control Software
    Last Post: 09-07-2018, 02:20 AM
  3. UC300 ethernet trouble
    By arachid in forum Controller Cards
    Last Post: 06-15-2018, 04:40 PM
  4. UCCNC & UC300
    By camivic in forum UCCNC Control Software
    Last Post: 10-27-2015, 08:45 PM
  5. UC300 interface
    By bickius123 in forum News Announcements
    Last Post: 09-19-2013, 07:44 AM
