Hi, I am in the planning stages of my first DIY router / mill project for hobby use on wood / Al. Nominal cutting area size is (hopefully) 30 in x 24 in x 4 in. There are some odd arrangements on my setup, but I think I am working through them.
My goal is to microstep / gear the setup so that 1 step = approx 0.001 - maybe 0.0002 in. , not that the end system will be that accurate of course.
I am estimating the gantry mass at 100 lbs / 50 Kgs, based on the posts of others, and my own parts list.
The plan is to use belt drives run off of stepper motors. On at least 2 axis, I would like to use a stepper motor with 2 shafts, put belt pulleys on each shaft, and drive the belts directly. At least in theory, this would provide a belt on each "side" of the axis drive, and reduce racking of the axis.
The particular stepper motor I am thinking about is this one: http://kelinginc.net/KL34H2120-60-4B.pdf . This is one of the standard Kelling size 34 stepper motors with a shaft from each side. I picked it just based on approx torque, 4 wires (because I don't know any better), length, and in stock. Feel free to suggest an alternative model.
So, now the question - Two each belt drive pulleys directly attached to the motor shaft and pulling the axis around will have considerable side load on the axis. I am not sure how much, but (maybe ?) 10 lbs on each side. I really need to do this calculation. Belt will probably be 25 mm wide AT 10 steel wire reinforced.
Is this OK to do with a stepper motor, or are they exceptionally side load sensitive ?
Most of the stepper motor installations I am seeing use the shaft to drive a coupling with separate bearings / shaft to deal with the side load, but it would of course be very convenient if the stepper motor could eliminate the extra parts.
Thanks in advance for any advice.
