585,894 active members*
4,873 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Path Pilot WCS does not coordinate with Fusion 360 WCS when posting program
    In other words I have set X/Y 0 as the lower left corner of my work piece on Fusion 360. If you look at the Path Pilot screen (see photo) you will see that X/Y 0 are actually in the center of the work piece. How do I correct this?
    Mar 2020
    218
    Re: Path Pilot WCS does not coordinate with Fusion 360 WCS when posting program
    Can you post the fusion file? Seems like there's gotta be something wrong there.
    Nov 2012
    591
    Have you probed/set the working coordinate offset zero yet?
    And are you sure the "stock box point" you use in the CAM is really the lower-left corner, and not the center, in the "Setup" tab?
    (Just checking -- those are the two things that immediately come to mind.)
    the first x move on your screen indicates that the code is not written to the bottom left corner of your part
  1. path pilot and fusion
    By toyshop in forum Tormach PathPilot™
    Last Post: 12-11-2017, 02:46 PM
  2. Differing start and end radius Fusion 360 to Path Pilot
    By davidperry3 in forum Tormach Personal CNC Mill
    Last Post: 08-30-2017, 02:06 PM
  3. How to start path pilot in the middle of a program?
    By LeeWay in forum Tormach PathPilot™
    Last Post: 07-31-2016, 12:55 AM
  4. Latest Path Pilot Post processor for Fusion 360.
    Last Post: 03-31-2016, 08:24 PM
  5. Has anyone tested the Path Pilot Post for Fusion 360?
    By cchan_ADSK in forum Tormach PathPilot™
    Last Post: 10-29-2015, 03:22 AM
