586,005 active members*
5,075 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > C axis unwinding on Haas 5X
    May 2020
    Hi All,
    *I'm using PowerMill 2020 on a Haas 5 axis trunnion type of machine.
    *I'm wireframe swarf cutting the entire periphery of a part with a constant
    5 degree draft.
    *In the simulation it all looks good.
    When executing on the machine*it leads in,machines around until reaching the point of passing C zero
    where it rotates C360.0 back to the same position it was at , then continues the path and leads off of the part.
    During this repostioning it does not lift z or reorient the A/C axis positions to prevent gouging.
    Is this a setting in the post , the PM software, or a machine setting?
    Dec 2008
    3109
    Re: C axis unwinding on Haas 5X
    It would be either a post or programmer error... I'd lean toward a programming error.
    .... long time since using PM, but look for a "Retract between Cuts" or possibly a "Keep tool down" setting
  1. Virtually unwinding 4th in Post Processor
    By carboxyll in forum BobCad-Cam
    Last Post: 03-06-2017, 02:04 PM
  2. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  3. Replies: 1
    Last Post: 01-14-2012, 06:22 PM
  4. 4th axis unwinding
    By Paul Goddard in forum Mastercam
    Last Post: 04-07-2010, 11:51 AM
  5. Unwinding a toroidal, what tape?
    By Greolt in forum CNC Machine Related Electronics
    Last Post: 03-30-2007, 03:43 AM
