586,005 active members*
4,932 visitors online*
    Apr 2020
    Mk3/4 Wiring problem
    Hi, I am new to this forum and a new customer of PlanetCNC. I am rebuilding a lathe with a MK3/4 board, PlanetCNC output board, new stepper drivers, stepper motors and a VFD and am part way through wiring the control cabinet. I am having an issue with the controller board losing connection with the PC when I run the VFD and start the spindle motor. By a process of elimination I have narrowed this down, when the controller is powered by the external 12V power supply the problem happens but when the controller is just powered by USB it doesn't. It is obviously some sort of interference or grounding issue but I can't work out what.
    I am using a quality, short, double shielded USB cable. The cable to the spindle motor from the VFD is shielded. Other wires are not shielded. I have disconnected all outputs and inputs from the controller to diagnose the issue. I am running the VFD directly (not through the software). The VFD is not connected to the output board yet. The 12V power supply is powering both the controller and output board - is that an issue or do I need separate power supplies? All components are attached to the metal cabinet and this is earthed. The power supplies are connected to earth. The controller board and output board are mounted on steel standoffs with paper washers. Power for the power supplies and VFD comes from a single mains socket.
    I would really appreciate any ideas on what is wrong. Would it help to use shielded cable from the power supply to the controller and output boards?
    Andy
    Jun 2017
    143
    Re: Mk3/4 Wiring problem
    You didn't mention if you had an EMI filter on the input power the the VFD. One of those is crucial to stop the noise from the VFD getting back into other components. Also even though you have a short shielded USB cable make sure it is routed away from the VFD cable and definitely not running paralell.
    Apr 2020
    Thanks - I dont have an EMI filter for the VFD
    Mar 2017
    1312
    I use "Schaffner AX-FIM1024-SE-LL" filter for VFDs in most of my projects.
  1. wiring problem with DMM DYN4
    By vipers95 in forum Centroid CNC Control Products
    Last Post: 10-01-2018, 07:00 PM
  2. Wiring problem
    By Mostafa10 in forum DIY CNC Router Table Machines
    Last Post: 10-30-2017, 04:34 PM
  3. HELP : problem with motor wiring
    By techsol in forum Shopmaster/Shoptask
    Last Post: 11-20-2012, 03:25 PM
  4. EMG wiring problem 18i
    By ulihuber in forum Fanuc
    Last Post: 01-31-2008, 12:41 AM
  5. EMC or wiring problem?
    By toninlg in forum Servo Motors / Drives
    Last Post: 04-30-2007, 06:20 PM
