585,605 active members*
3,070 visitors online*
    Oct 2019
    12
    Measurements Off in Mach3
    I have a USB 6040 Chinese machine. I have cut several things with it and they have turned out ok, but they have all been small. Yesterday, I cut something that was 17.5 inches long. I had a box that was supposed to be centered in the material, but it was off. Then I noticed that although my piece measured 17.5 inches, if I jogged the axis from one end of the material to the other, it measured 20 inches in Mach3. I went back and calibrated my motors again and they were off very slightly. I fixed that, but my measurements are still far off by the same amount. I am telling Mach3 to move the axis one inch. I use my micrometer to measure. I am sure it is not NASA quality measuring, but it is very close. I don't think it could be enough off to cause 2 and 1/2 inches in difference in a 17.5 inch span. Should I go back and tell the machine to move 20 inches and see tell the machine it moved 17.5 and see if it fixes it? Is there some other variable I am unaware of? Any help would be appreciated!
    Re: Measurements Off in Mach3
    Yes, tell the machine to move 20" and see if it actually moves 20"
    Oct 2019
    12
    That fixed it! Thanks. I wasn't thinking how only a fraction of an inch would add up the bigger the job was. So, I used the 20 inch and it only moved 17.5. I plugged that in to the box and it fixed it. I was using the small measurement because my micrometer only goes so big. I am sure it is not perfect now, but it is close enough for me to keep learning... Thank you again,
    Scott
  1. A Few Measurements Needed...
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 01-30-2013, 01:15 AM
  2. Need NM-200 Measurements
    By MRM RCModels in forum Novakon
    Last Post: 03-06-2012, 06:54 PM
  3. X2 Spindle Measurements
    By michaelthomas in forum Benchtop Machines
    Last Post: 03-21-2011, 04:33 AM
  4. sieg x2 measurements?
    By ihavenofish in forum Benchtop Machines
    Last Post: 08-13-2009, 07:13 PM
  5. Need Help with some Gear Measurements
    By Kain in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2009, 03:24 AM
