585,932 active members*
3,802 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > write feed in gcode file based on line steepness
    Mar 2018
    Hello,
    I am looking for a way to edit a gcode file to write the feed rate on every line that is steeper than a certain angle because the machine i work on gives me a error when traveling in Z on faster feeds.
    Thank you.
    Dec 2005
    594
    Re: write feed in gcode file based on line steepness
    G Code files are just text files, so pretty much any text editor will work.
    Mark
