585,767 active members*
4,182 visitors online*
    Jan 2012
    163
    What wire to use?
    I would like to extend my wires for my nema 34 motor, the motor has 6 amps printed on the label and I'm using 60 volt power supple will it be ok to use 18 awg wire?
    Jan 2018
    1516
    Re: What wire to use?
    Yes. I'm using the same at 3 metre lengths with GX20 connectors.
    Jan 2012
    163
    I was worried about 18 awg wire getting hot and melting or starting a fire i was not sure
    Dec 2012
    192
    Hello.
    I use 16 AWG for up to 6 meters with no overheating at all. Then I use wire nuts for the motor to cable connections.
    Best regards.
  1. Sodick AG600L Wire EDM - EDM wire rewinds to spool after cut at end of program.
    By nlancaster in forum EDM Discussion General Topics
    Last Post: 04-19-2022, 08:02 PM
  2. Mitsubishi FX-10 1997, Problem with wire detection before the wire chopper.
    By Jeff247 in forum EDM Discussion General Topics
    Last Post: 10-29-2019, 03:26 PM
  3. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  4. Mitsubishi wire type setting for zinc coated wire
    By Futurewire in forum EDM Discussion General Topics
    Last Post: 01-25-2011, 01:49 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
