585,933 active members*
3,848 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Blue Elephant CNC > The first best-selling machine recommended-an entry-level 1325 CNC router machine
    Nov 2011
    261
    This 1325 woodworking engraving machine is also known as an entry-level woodworking engraving machine by users. From the processing path, this is also a three-axis engraving machine. During the processing of the three-axis engraving machine, the work piece always remains stationary, while the cutting tool moves along the three axes to process the work piece. When the three-axis CNC engraving machine is engraving, whether it is flat carving or round carving, it can be imagined as a plane carving. It is mainly suitable for engraving plane and bilaterally symmetrical, uncomplicated patterns, such as olive core, 461 brand, etc.The reason why this woodworking CNC machine is considered to be an entry-level engraving machine in the woodworking machinery industry is because this CNC machine is simple to operate and does not require special training. The operator can complete the machine operation independently. In addition, the procurement cost is low, and maintenance and repair are relatively simple. Therefore, both in operation and maintenance, it is more suitable for new users.
    Attachment 443040
    Re: The first best-selling machine recommended-an entry-level 1325 CNC router machine
    Thanks, Do you have access to the manual of this machine using DSP and ARTcam as software?
  1. Entry level machine
    By Submoafirearms in forum CNC Machine Related Electronics
    Last Post: 04-02-2014, 05:32 AM
  2. Any suggestions for an affordable, entry-level CNC machine
    By drosen99 in forum Commercial CNC Wood Routers
    Last Post: 11-06-2012, 10:17 PM
  3. New Small Entry Level Engraving Machine
    By CNC602 in forum News Announcements
    Last Post: 03-29-2012, 04:30 PM
  4. need some advice on entry level machine
    By pa2262 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-24-2008, 02:45 AM
  5. Looking for an Entry Level CNC machine
    By pk_volt in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2008, 07:41 AM
