585,996 active members*
4,722 visitors online*
IndustryArena Forum > Maintenance in General > SERVICE FOR CNC-MACHINES > Strange Problem with Mitsubishi Meldas 500
    May 2020
    8
    Hi, I have a milling machine equipped with Mitsubishi Meldas 500 and I have a very strange problem. The machine starts properly without any error. All axes are working without error and I can move them but... when I start the operation of AUTO ZERO then it gives M01 OPERATION ERROR 0102 which means that the feed override is at 0 but it's not on 0! I tested the rotating selectors switch and it's working properly there is no problem with the feed override selector switch. Does anyone has any idea what can hold the AUTO ZERO function? I'm trying to find the ladder but for Meldas 500 is impossible, I cannot see it so I'm blind on this problem. I need help!!!!Thank you in advance.
    May 2020
    8
    Re: Strange Problem with Mitsubishi Meldas 500
    Thanks but I'm in Bulgaria and I suppose that this network cannot give me solution for local service... or it can?
  1. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  2. Mitsubishi Meldas 320 MV spindle orientation problem
    By petroff in forum Mitsubishi controls
    Last Post: 08-06-2018, 10:20 AM
  3. Mitsubishi Meldas M65 tool change problem
    By tbilecen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2010, 12:23 AM
  4. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2010, 06:40 PM
  5. Problem in mitsubishi meldas
    By mazman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-30-2009, 12:36 PM
