585,996 active members*
3,850 visitors online*
    Hydraulic Motor
    We have a hydraulic motor on an injection molding machine. It is a hydraulic driven motor, not a hydraulic pump.
    The most has thrown off the rings that connect the pistons. There is damage to the rings but nothing else has the slightest mark on it.
    We have been told that we need to buy a new motor at a cost of several thousand pounds.
    Surely we can just get these rings made rather than buy a whole new motor?
    Does anyone have any thoughts please?
    Nov 2013
    4372
    Re: Hydraulic Motor
    you might try some of the automotive Engine reconditioners. Some of them will make rings to suit.
    My understanding is that they are turned from white cast iron tubes. I further understand it is the 'barrel' grind
    that is applied that determines its suitability as a compression ring.
    Craig
    Dec 2013
    5717
    Re: Hydraulic Motor
    Maybe you can have new rings made. Without knowing more about the motor it is difficult to say how to proceed. I'm surprised that there are no repair parts available for that motor.
    Jim Dawson
    Sandy, Oregon, USA
  1. hydraulic motor not geeting ON
    By rakeshchauhan in forum Daewoo/Doosan
    Last Post: 07-09-2015, 06:26 AM
  2. Hydraulic Motor Overload.
    By Temo in forum Cincinnati CNC
    Last Post: 10-18-2012, 05:49 AM
  3. GEN-TECH HYDRAULIC MOTOR
    By keyancnc in forum Linear and Rotary Motion
    Last Post: 09-24-2010, 03:08 PM
  4. Hydraulic motor and pump?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2008, 08:53 PM
  5. Hydraulic pump and motor?
    Last Post: 07-28-2006, 06:30 PM
