585,712 active members*
4,409 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > need to enter CMOS on Dynapath delta 50
Results 1 to 6 of 6
    May 2020
    I had to replace the mother board battery on my Tree mill with Dynapath Delta 50 contol. but how do I enter into CMOS?. the Control has no F1, DEL button. there is no input for a keyboard either. Anyone know the secret?
    Please help.
    Aug 2011
    121
    Re: need to enter CMOS on Dynapath delta 50
    Do you have an AT type keyboard or PS2 keyboard with 5 pin DIN adapter to plug into the keyboard port on the bottom of the Delta 50 control?
    RT
    May 2020
    my Delta 50 control does not have this adaptor. I searched all over even inside the cabinet.
    Aug 2011
    121
    jmac429,
    The keyboard connector is on the Delta 50 motherboard. If your control is mounted in the traditional configuration with the cards on the bottom right, the keyboard connector will be on the underside of the control just to the left of the card slots. It should be a 5 pin DIN connector.
    You will need an old style PC keyboard with PS2 connector and a PS2 to AT adapter. I can take a picture later if you need.
    RT
    May 2020
    I found it!! Awesome! thank you very much.
    JM
    Aug 2011
    121
    Glad the information was useful. I keep a keyboard inside the cabinet for occasional use.
  1. dynapath delta 20
    By AWALTERS21 in forum Dynapath
    Last Post: 09-29-2012, 06:52 PM
  2. dynapath delta 20
    By dodgetruck23 in forum Want To Buy...Need help!
    Last Post: 10-10-2011, 11:54 PM
  3. Dynapath Delta 40
    By racear*2865 in forum Dynapath
    Last Post: 01-10-2010, 02:05 PM
  4. delta dynapath
    By camtd in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2008, 06:45 AM
  5. dynapath delta 10 help
    By undertowx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-05-2006, 03:49 PM
