585,927 active members*
3,513 visitors online*
    Nov 2015
    8
    Mach 4 not seeing PMDX-424
    Greetings,
    I have finally been able to get to work on my CNC machine after nearly a year. It's all wired in and ready to go however my mach 4 hobby build refuses to communicate to my pmdx-424. I've tried two different cables and all the USB ports.
    I looked on the device driver and I see the Intel(R) Active Management Technology SOL(Com3) which according to the manual in support means I have to send you a debug file so sent it to PMDX.
    I am thinking that My Altera quartusII FPGA software driver took over this port and is using it instead of Mach 4 (I am using the usb blaster) Could this be mistakenly thinking the PMDX-424 is a usb blaster?
    That's all I can think of at the moment. Has anyone else had this issue? If so what fixed it? I removed the board, unplugged everything but the power and still nothing.
    Here is an overview of my setup:
    I am running an AVID CNC 48x24 standard kit with nema23 steppers. The PMDX 424 is hooked up to 4 DM5565 Leadshine stepper drivers
    When turned on the PMDX424 has three amber LED lights (Power Enable and relay. I am told these should NOT be all on) on the board that light up, the red LED is solid while the green LED blinks at a 2 second interval.
    I made sure to install the smartBOB usb drivers before plugging it in as per the instructions.
    Thank you for the help.
    Nov 2013
    4371
    Re: Mach 4 not seeing PMDX-424
    I can't help you, my experience is with the ESS, but PMDX support is legendary, they will help.
    Try on the Mach4 forum and Steve will reply.
    Craig
    Sep 2005
    1740
    I have the PMDX 416 running on Windows 10 USB. Sounds like it might be your computer. Mine is a Intel NUC the very basic one and older with a VGA out. Has 4 USB ports, and runs this CNC which is a Chinese Work Bee, my laser machine and 3D printer. My Chinese machine came with a NUVUM something but I decided to go with Mach4 and the PMDX The NUC is using a LCD monitor I had, and of course I needed to install a SSD HD, 8 Mb memory and the OS but its very reliable.
    As a side note I used a Macbook Pro with Parallels installed to test and run the setup and it did fine even running the USB for the PMDX board.
    Nov 2015
    8
    The board was defective. It was replace and now it works great Thanks!
  1. WARNING: Backlash Compensation Problem in Mach 4 / PMDX SmartBOB
    By denvermatt in forum Benchtop Machines
    Last Post: 06-29-2017, 04:23 AM
  2. Replies: 1
    Last Post: 12-14-2016, 03:10 AM
  3. Replies: 0
    Last Post: 02-26-2014, 03:41 AM
  4. Having Issues w/ PMDX-126 PMDX-134 and Ethernet Smooth Stepper
    By Hurshy in forum Community Club House
    Last Post: 08-27-2013, 01:20 PM
  5. Mach 3 with a PMDX 126 Board , 107 spindle board
    By jandalaser in forum Mach Software (ArtSoft software)
    Last Post: 05-18-2012, 09:38 PM
