I have Alphacam ultimate i need help on how to engrave, machine on the diameter ,cylindrical machining (radial ) my machine use code G107
the process i did was make a round surface on the diameter of the part select work plane and i add text , on c axis machining i use 3D engrave and later project to the surface the tool does the engrave on the part but the material is not rotating (no C axis move ) like a regular projected engraving on the mill
also i try to use the command Rough/Finish on C axis machining and does the C movement but the approach ,safe level is doing it on Z when suppose to be in X ( like axial machining )
what i am doing wrong , if helps i have a Doosan 2100 M lathe
thanks
