Hi sir ,
I am nishil Patel from Vancouver Canada .
I have Nakamura tome make methods slant 1 turning centre lathe machine having a control 3T F .
The problem is when i sending a program from computer it shows P/S alarm : 086
following are the setting of the machine parameter
parameter 1 : - 10111010 (Bit 4=I/O ,bit 1 = ISO , BIT 0= TV CHECK )
PARAMETER 5 BIT 0 = 0
PARAMETER 14 BIT 0 =0
PARAMETER 68 = 4800 (BAUD RATE)
PARAMETER 69 = 4800 (BAUD RATE )
FOLLOWING ARE THE COMPUTER SETTING : -
BAUD RATE = 4800
DATA BITS = 7
ASCII = EVEN
STOP BITS = 1
HAND SHAKE = X ON/X OFF
PORT TYPE = STANDARD
CONNECTOR DETAILS OF THE 25 PIN D TYPE MALE CONNECTOR(DB 25 CNC ) AT MACHINE SIDE FROM FANUC SYSTEM 3T F AT MASTER PCB DOOR
1= SHIELD
2=RED ( TRANSMIT DATA)
3 GREEN (RECEIVE DATA)
4 & 5 SHORTED (5 IS FOR CTS AND 4 IS FOR RTS)
6= BLUE
7 = WHITE (MAY BE SIGNAL GROUND )
8 & 20 SHORTED (8 IS FOR DCD AND 20 IS FOR DTR )
NOW THE PROBLEM IS I AM USING WINDOWS 10 COMPUTER HAVING A GIBBS CAM SOFTWARE WITH IT AND I AM USING ONE USB TO 9 PIN CONVERTER AND 9 PIN CONVERTER TO 25 PIN D TYPE CONNECTOR WHICH IS DIRECTLY GOING IN TO THE MACHINE DB 25 PIN MALE CONNECTOR , IN SHORT
USB>9 PIN D TYPE CONNECTOR >25 PIN D TYPE CONNECTOR >25 PIN D TYPE MALE CONNECTOR OF THE MACHINE .
WHEN I SELECT EDIT MODE AND SEND PROGRAM WITH STARTIG O00001 AND PRESS INPUT , 086 ERROR CAME .
SIR ,
PLEASE HELP ME TO RECTIFY THE ISSUE...
NISHIL (ZONE 7)
