584,863 active members*
4,894 visitors online*
Results 1 to 6 of 6
    Feb 2005
    53
    Question New Build Questions
    Ok So I have probably gone about this the wrong way but :0 I'm new to lasers.
    I have bought a chinese 100W tube and Power Supply.
    I want to use Mach 3 as I am use this software for my laser. Plan to do engraving and cutting (Model Aircraft Parts). Will mach3 be suitable for what I want to do?
    How do you suggest getting the laser to fire with Mach3? Im sure for the parts it wont be an issue to just use the spindle but not sure about the engraving on/off speeds.
    Is there a controller (BOB) I should be looking at which will run the g-code as it comes either way I decide to run it. I'm on a budget.
    Suggestions would be appreciated.
    Prboz
    Apr 2005
    304
    Cool Re: New Build Questions
    On what kind of machine you're going to place the tube?
    Mach3 is bad when it comes to control laser. I can suggest you to use GRBL (on Arduino platform) as motion controller when dealing with lasers.
    On machine that I use I have a router () and 2.5W laser module. Routing-cutting-engraving is controlled with Mach3, when it comes to laser, I just swap BOB with GRBL and use different software (LaserGRBL) or LightBurn.
    LaserGRBL: https://www.youtube.com/watch?v=P7El-Vc4RBg
    Mach3: https://www.youtube.com/watch?v=9PeqHJFd0uY
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Feb 2005
    53
    I'm actually making a machine from scratch.
    Apr 2005
    304
    As I wrote, no mather is it is machine built from scratch or you intend to modify the existing one, I would not recommend Mach3/4
    Here's some info on controlling a laser with Mach3.
    http://tweakie.byethost10.com/27_files/Page652.htm
    Nov 2013
    4282
    Mach3 was developed before laser operations were commonplace amongst hobbyists and given that all development of Mach3 ceased six years ago the prospect
    of Mach3 being a good control solution for laser operations is poor.
    Mach4 is a very much newer and developing software solution.It has some specialised instructions for laser operations and the Ethernet SmoothStepper has realtime
    laser vectoring/rastering features. My understanding, from others, who have used the combination report good results.
    Craig
  1. Getting ready for a 4x4 build some simple pre build questions
    By lonzo in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-03-2015, 04:58 AM
  2. Some questions for a new build
    By mabod in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-08-2012, 01:01 AM
  3. New Build Have Some Questions
    By aussiecncer in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-31-2011, 07:05 AM
  4. New Build Questions
    By PCFlyer in forum CNC Wood Router Project Log
    Last Post: 11-16-2010, 09:14 PM
  5. Questions about a new build
    By bandtank in forum Joes CNC Model 2006
    Last Post: 10-24-2009, 03:31 AM
