585,969 active members*
4,501 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan VCF850L - Alarm 2164 - Oil Cooling Unit Alarm
    Hello,
    We received a VCF850L at the end of 2019. Machine has been running great except for periodic issues with the spindle oil cooler (nanocon CIL1101A).
    The machine usually runs just fine, but some times we get this 2164 alarm, which shows as AL05 on the cooler.
    The cooler manual states for AL05:
    Description: Main spindle protective oil pressure switch (S60) are actuated
    Cause: It occurs when flow rate of pump outlet is below 0.1Mpa
    Sometimes this issue goes away after leaving the machine overnight.
    Other times we've had the service guys from the dealer come.
    I'm not 100% sure what it is that they do, but my operator says that they bleed off the hoses.
    Anyone familiar with this issue?
    Feb 2013
    788
    Re: Doosan VCF850L - Alarm 2164 - Oil Cooling Unit Alarm
    Here are the Service manuals for the chiller.
    The issue may lie in a low oil level, improper hose connections causing issue, clogged inline filter, or other obstruction, as well.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  1. EX 451 spindle drive unit alarm
    By Asfar in forum Fanuc
    Last Post: 11-07-2020, 09:43 AM
  2. 360 spindle cooling malfunction alarm in yellow
    By BigT00 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-05-2018, 02:56 PM
  3. Sp. cooling flow alarm D 171.0
    By dibakar in forum Fanuc
    Last Post: 12-31-2010, 03:52 AM
  4. J/C unit alarm (pallet changer)
    By padobranac in forum Fanuc
    Last Post: 09-25-2008, 08:28 PM
