585,883 active members*
5,196 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 5 axis chinese BOB home switch question
    Jan 2004
    85
    Is there a way to test on the board itself whether the home switches are working. this is on a home built cnc router that I've had for years and just decided to put home switches on it. I just added the spindle to the relay to turn on and off and that works fine. On a side note this is running on cncpro from yeager automation. The attachment is the board I have. Thank!
    Greg
    Jan 2018
    1516
    Re: 5 axis chinese BOB home switch question
    Quote Originally Posted by gv71 View Post
    Greg
    For a start. The inputs for home/limits/e-stop & spindle 0-10v output only work if you plug a 12-24v power supply into the 2 connections on the right.
    The 5v in from the usb only runs the outputs to the drivers.
    Jan 2004
    85
    thank you!!!
  1. Y axis not reference - missing home switch on current axis
    By mits007 in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2020, 11:13 PM
  2. Replies: 2
    Last Post: 06-29-2018, 08:08 PM
  3. chinese 6040 home switch
    By stallified in forum Chinese Machines
    Last Post: 05-07-2014, 01:43 PM
  4. X2 Z axis home switch mounting.
    By TXFred in forum Benchtop Machines
    Last Post: 02-19-2011, 02:54 PM
  5. Limit/Home Switch Question
    By JeLC in forum LinuxCNC (formerly EMC2)
    Last Post: 03-22-2009, 01:08 PM
