586,005 active members*
5,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil Spindle Still No Bueno -
Results 1 to 15 of 15
    Oct 2013
    36
    Hey All,
    I'm at my wits end with this Syil X4. I've had the spindle board rebuilt, still no movement. Vid here on where I'm at:
    At this point I'd be happy to replace the spindle control (and motor if necessary) Anyone PLEASE!!! Help!
    Anything I haven't tried with my current set up?
    Anyone who has replaced all the guts in your Syil X4?
    Please hook a brother up
    Thanks,
    CE
    Mar 2017
    411
    Re: Syil Spindle Still No Bueno -
    duplicate post
    Mar 2017
    411
    Do you have a photo of the controller card?
    Is it an XMT_DRIVER_1500 like this one?
    https://www.cnczone.com/forums/bench...-sx4-bldc.html
    Jun 2007
    3757
    Pictures of PCBs so I know which of the many versions you have. I hAve most if the schematics.
    Your problem is in the big motor controller PCB.
    Can be a simple as e-stop lockout. Most wiring is failsafe so any broken wire will kill it.
    As your display and buttons work small parallel port board and front panel are good.
    Pictures please.
    Oct 2013
    36
    When I had everything pulled out that went to the rebuilder....
    Attachment 443550
    If any close up shots will help I can take more pics
    Thank you!
    Jun 2007
    3757
    Quote Originally Posted by lockbuilder View Post
    Attachment 443550
    Thank you!
    I believe your safety relay on main board won't be closing.
    If that is the case you won't have any voltage on the big electrolytics. Be careful. All this stuff is at mains potential.
    I don't have a schematic of your version.
    What is the psrtnumber(s) on all of the boards.
    Each version the idiots got from east-crystal are different because no proper specs for machine. EC don't care, 'cos they they just charge for development cycle again. The rot continues.
    Oct 2013
    36
    Hey Neil,
    The big board at the bottom is:
    Honcar HBLC-1100-300H-S0018A
    Power Main Board Ver 1.0 2012.05.18
    The little board at the top is:
    Tonman PCF12171 Rev. 1.1
    Thank you!
    Chris E.
    Oct 2013
    36
    Oh and the A is in parens.......
    Honcar HBLC-1100-300H-S0018(A)
    sorry,
    CE
    Jun 2007
    3757
    Sorry. Don't recognize any of those numbers.
    Try this: Closest I could find. Look at page 41. Get the Estop wiring correct.
    Ref:
    https://manualzz.com/doc/6958602/x4-plus---syil-america-bench-top-cnc-mills
    Oct 2013
    36
    Neil and Maxspongebob,
    I was hoping you guys would show up! You both have tried to help me before. In fact in the last thread someone recommended the guy I sent the board to for rebuild
    Attachment 443548
    Previous thread.
    https://www.cnczone.com/forums/syil-...ive-motor.html
    Can you guys please share the solution if one was found? I have an X4 style machine but it is older and slightly different but I can't get MACH3 to control the spindle either. Thanks!
    Mar 2017
    411
    Quote Originally Posted by anime2485 View Post
    What are the identifying marks on your spindle controller?
    Look here for my solution. https://www.cnczone.com/forums/bench...-sx4-bldc.html
  1. Syil SX3 Spindle Control
    By Megaplow in forum Syil Products
    Last Post: 06-17-2013, 06:34 AM
  2. Syil X7 spindle wont run
    By pdh8953 in forum Syil Products
    Last Post: 05-15-2011, 05:15 PM
  3. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  4. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  5. Syil SX3 spindle play and fix
    By david_geng in forum Syil Products
    Last Post: 08-07-2009, 10:56 PM
