585,954 active members*
4,650 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > SPiral interpolation macro
    Hello Everyone,
    I wanted to make a parametrised macro for spiral milling for Fanuc.
    I don't know what is the error in this program:
    #14=95.02 (DIAMETER OF THE HOLE)
    #11=0.05 (PITCH)
    #21=0.5 (LENGHT FOR CHAMFER(FOR EX 0.5X45 DEGREES)
    #9=#14+[2*#21]+[4*#11] (DIAMETER FOR BEGINING MACHINING)
    #19=#14+[2*#21]+[6*#11](DIAMETER FOR BEGINING MACHINING)
    #10=0 (Z PLANE; FOR EXAMPLE Z=0)
    #32=#10+[4*#11]
    #33=#10-#21-[4*#11]
    N10 G21 G17
    (CICLU SANFRENARE UNGHI 45 GRD DIAMETRU INTERIOR)
    N20T1 M06
    N30 G0G90G54.
    N40 S2000 M3
    N50 G0 X0. Y0.
    N60 G43 Z10H1 M8
    N70 G94G1Z0.2F1000.
    N80 G41D1X0.
    N80 G1 G91 X0. Y-48.21 D1 F1000
    N100G1G40Y48.21
    WHILE [#32 GT #33]DO1
    G3 X0 Y#9 Z-#11 I0 J[#9/2] K-#11
    G3 X0 Y-#19 Z-#11 I0 J-[#19/2] K-#11
    #9=#9-[4*#11]
    #19=#19+[4*#11]
    END1
    N100G1G40X-50
    N110G0G90Z10.
    N120G0G91G28Z0
    N140M0
    M30
    Feb 2011
    353
    Re: SPiral interpolation macro
    #9=#9-[4*#11]
    #19=#19+[4*#11]
    END1
    WHILE [#32 GT #33]DO1 #32 will always be the same number #32=#10+[4*#11]
    you will need to have a modifier between the while statement and the END1
    Are you trying to generate a chamfer with a 3 axis move ?
    i did not look to see if your center of arc is correct or not as you are changing the dia. during the cut and not moving to a new starting point (the center point won't be the center starting point of the hole)
    this would be correct J[#9/2] if you started at #9 arc dia.
    Yea. I'm trying to make a chamfer. But i don't know how...
    Feb 2011
    353
    What kind of end mill do you intend to use ( sharp corner, ball end mill, an end mill with a chamfer / radius corner )
    the type of end mill will make a difference in the programming and how the surface finish comes out
    I need 2 kinds: one program with sharp corner and another with a parametrized radius if you can.
