585,991 active members*
4,544 visitors online*
    Sep 2006
    340
    Question Anybody had this problem in Mach 3?
    Is there anything in mach or the thc 300 that can multiply feedrates? I notice that the feedrates are much faster than they should be. The Feedrate override when loading a program jumps to a 1200% increase....
    Even without a program start?
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    The highest Mach3 should let you set the FRO is 300%. Could be a corrupt .xml
    Sep 2006
    340
    Question
    How to fix that? The pendent will let go to 9999%, never ran it above 3 or 400. but the program make it go streight to1200%. I had to make the feedrates really low in order to cut prperly....
    Thanks Marc
    Delete the .xml file and reconfigure from scratch. Mach backs up the .xml file automatically, you might want to try reverting back to an older one. You should be able to find them in the Mach folder.
  1. mach 2-3 pin&port problem
    By pislik in forum DIY CNC Router Table Machines
    Last Post: 01-05-2012, 09:36 AM
  2. G202 & Mach 3 problem
    By Hillcraft in forum Gecko Drives
    Last Post: 01-06-2007, 07:06 PM
  3. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
  4. Mach 2 Estop problem
    By dentman in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2005, 01:32 AM
  5. mach 2 problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2005, 09:12 PM
