585,779 active members*
3,779 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Sinumerik 840 C Post options
    Hi
    Does someone know where to find documentation on Edgecam post editing?
    I made a post for a Chiron FZ12 with Sinumerik 840C but NC code contains a TURN command which is not recognized by my controller
    Which option turn this command off?
    thanks
    Oct 2003
    127
    Re: Sinumerik 840 C Post options
    if you open your generator in code wizard and go to NC styles, G-code and modality then select debugging tab and turn on "generate code constructor trace" and repost your program, you will get information about where each piece of code is attached to what cycle or process controlling output so you can go back to the right area in code wizard to tweak what you want to see.
  1. post-processor for a Sinumerik 840
    By Lval in forum EdgeCam
    Last Post: 10-23-2019, 04:53 PM
  2. Post DMF 220 Sinumerik 840D
    By kickinger in forum Post Processor Files
    Last Post: 10-25-2016, 12:02 PM
  3. I need a post processor for Sinumerik 810GA3.
    By aerecek in forum Post Processor Files
    Last Post: 10-04-2016, 11:47 AM
  4. NX / Sinumerik Post problem
    By D_Turner in forum UG NX
    Last Post: 08-02-2013, 03:29 PM
  5. who has the post for sinumerik 802d
    By eric_hou in forum PTC Pro/Manufacture
    Last Post: 07-21-2008, 01:01 PM
