585,981 active members*
4,582 visitors online*
Results 1 to 6 of 6
    Mar 2020
    4
    Shank diameter
    Hello,
    Is there any website that serve as guide to ratios between the endmill and shank diameter? A small company where I work received a request from a client for a carbide tipped stub length drill. The issue I find however is that shank diameter is only 3/8 while the rest of the endmill is 55/64. It seems to me that shank diameter is too small and ideally I would like to recommend a viable alternative to their request. Any suggestion is greatly appreciated. Thank you.
    Nov 2012
    591
    Re: Shank diameter
    Are you sure that's not a typo? 3/4 would be more reasonable ...
    Apr 2013
    1788
    Re: Shank diameter
    See Silver and Deming Drills | Norseman™ Drill & Tool for some information that may be useful to you.
    Feb 2011
    353
    Re: Shank diameter
    an alternative use for the 3/8 shank could be for a swiss machine
    the one's i run are er16 collet style which would give a max shank size of 10mm (.3937)
    stub style would be the preferred cutting because of the limited length allowed in the machine
    the machines couldn't handle a full cut like a vmc so it is lite ipr's and it's probably being used to open up an existing hole if used on a swiss
    side note NTK offers a .787 dia 3 flute indexable with a shank to fit a er16 collet
    Nov 2013
    4372
    Re: Shank diameter
    I have found the Harvey Tools Catalogue a useful store of information.
    Craig
    Mar 2020
    4
    Re: Shank diameter
    Thank you very much for your responses. I will go see on those websites.
    @jwatte, no it's not a typo. It really is 3/8. The issue is that the whole piece is in carbide and it will definitely break off. This is why I was asking if, for safety reasons, what would be the minimal diameter we could reocmmend. I was thinking 1/2. Do you guys think 3/4 would be more acceptable?
  1. End Mill Shank versus Cutting Diameter
    By syscore in forum Tormach Personal CNC Mill
    Last Post: 07-12-2017, 04:12 AM
  2. Replies: 2
    Last Post: 10-07-2011, 10:56 PM
  3. 3/8 or 1/2 shank end mill or indexable with at least 1" cutting diameter
    By claytonstoker21 in forum MetalWork Discussion
    Last Post: 02-03-2011, 02:09 AM
  4. 1/2" DIAMETER T-Slot cutter with long shank?
    By panaceabea in forum MetalWork Discussion
    Last Post: 08-29-2009, 12:40 AM
