585,761 active members*
3,980 visitors online*
    Jul 2017
    26
    Gantry Y Ideas (DATRON M8Cube)
    Datron's M8Cube CNC looks very interesting to study. Unfortunately it is difficult to find photos and videos to better understand your design.
    I would like to understand what gantry Y looks like, where are the linear guides and the ball screw?
    Does it have only 1 ball screw and 1 motor on the Y axis? Are the linear guides attached to the underside of the polymer concrete table?
    Apr 2021
    Re: Gantry Y Ideas (DATRON M8Cube)
    Quote Originally Posted by Vitali-M View Post
    Gantry is welded steel structure with 2 linear guidways one on the front and the other on the bottom of gantry.
    Y axis is 2 seperate linear guideways on each bottom side of polymer concrete table with two 200 watt servos and 2 ground ballscrews C3
    This design is very clever regarding the weight distribution, very high acceleration, chips management and precision.
  1. Need thoughts and ideas on changing a single sided gantry to 2 sided gantry...
    By RECELECT in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-17-2016, 07:49 PM
  2. Datron cnc
    By bunalmis in forum Hard / High Speed Machining
    Last Post: 10-06-2015, 11:46 AM
  3. Replies: 0
    Last Post: 03-31-2014, 03:20 PM
  4. gantry design ideas
    By oneturboneeded in forum DIY CNC Router Table Machines
    Last Post: 12-14-2011, 06:19 PM
  5. Manual & small overhead gantry style - moveable bed plans, ideas...
    By nadsab in forum DIY CNC Router Table Machines
    Last Post: 08-30-2010, 03:22 AM
