586,011 active members*
4,466 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Feed rate problem when jogging with jogging keyboard.
    Jan 2007
    31
    I am facing a problem with an older Mk3/4 which I use many years now.
    Recently, I bought the jogging pcb and trying out I found that it does not have constant feed rate.
    Every time I move an axis, it uses different feed. In the video , in the beginning it goes I think 2.500mm/min, then drops to 500mm/min something like that.
    If I enable the speed adjust option, the pot does nothing (maybe due to the old Mk3/4?) and the machine moved with variable feed.
    I use the classic software with this machine due to the old Mk3/4.
    Any ideas?
    Jan 2007
    31
    Re: Feed rate problem when jogging with jogging keyboard.
    And this video is with speed adjust on and just pressing the move axis button
    Jan 2007
    31
    UP
  1. Jogging keyboard dxf
    By schesby in forum PlanetCNC
    Last Post: 01-01-2020, 06:14 AM
  2. Jogging keyboard with potentiometer question
    By pwogger in forum PlanetCNC
    Last Post: 08-23-2017, 09:16 PM
  3. Sluggish Keyboard Jogging
    By nelZ in forum CamSoft Products
    Last Post: 10-20-2008, 08:42 PM
  4. Delayed keyboard jogging
    By alfalfa in forum CamSoft Products
    Last Post: 08-13-2008, 05:18 PM
  5. Jogging 4th axis with keyboard?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 11-09-2007, 04:44 PM
