585,676 active members*
4,409 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help Me Drive Some Servos Please!
Page 1 of 3 123
Results 1 to 20 of 42
    May 2011
    790
    Hi everyone. It’s been a while since I’ve posted on the forums, for the past few years I’ve been busy working, overtime every week, etc. But now, like so many other people, I now find myself with some spare time on my hands, and a new project to work on.
    And I need some help!
    I bought a couple of surplus linear stages for an industrial quality 3d printer build. Now I am trying to decide how I should power them.
    The stages came with AC servos.
    Tamagawa Seiki
    TBL-S
    TS4073N9E31
    300W
    200V
    2006
    I tried to find some more info on these from the Tamagawa Seiki website, but was unsuccessful. It looks like the “TBL-S” series is a legacy product, and I could only find info for their current line of servos. Does anyone know where I can find a manual or product catalog for these?
    They are quite large, almost the size of a Nema 34. Much larger than the new series from Tamagawa Seiki that replaced them. There are 4 wires for the motor and about 15 wires for the encoder.
    It would be nice to figure out a way to use them. They are absolutely brand new, never been used.
    For the control board, I’m heavily leaning towards either a Duet 2 or a Duet 3 running an expansion board. These boards are specifically made for 3d printers and have great support and software options geared towards 3d printing. To do this I would need a servo driver that can accept step / dir inputs. Any suggestions, preferably something I can find surplus on EBay? Something that has a single phase 110VAC input would be ideal.
    I am considering running them at a lower voltage. The link below is an old thread some of this was discussed previously. I'm also looking to find a Kv rating for these servos, which is explained by jfong in post #11 in the thread below. Like I mentioned, these servos have been replaced by newer versions and I can't seem to find any literature on them.
    https://www.cnczone.com/forums/servo...33064-cnc.html
    I was thinking of using the Leadshine ACS806, which is an AC servo driver, but has a max input of 80VDC, which I assume translates into about 80 VAC after the driver.
    Object reference not set to an instance of an object.
    A couple of concerns I have….
    1. I have no idea if the servo encoder on the Tamagawa Seiki servos is compatible with these drivers.
    2. I don’t know how using lower voltage will affect the performance.
    For stepper motors, running at a higher voltage effects the torque available at higher RPM’s, and running at higher current affects the torque available at low RPM. For example, you can have the exact same holding torque on a stepper motor that is running at a lower voltage.
    But for these AC servo motors I'm not sure what will happen.
    Does it reduce the torque at low RPM or does it only affect the performance at higher RPM’s? I don’t need to be able to run these servos at 3000 RPM.
    Another option is to run these linear stages using Nema 23 stepper motors, but for a 3d printer, it would be really nice to be able to use servos.
    Any input is appreciated.
    Nov 2013
    4358
    Re: Help Me Drive Some Servos Please!
    is it really worth that much just to keep old servos running?
    A 400W B2 series Delta servo, drive and cables delivered to the US for $378....is it worth messing around when you could have new servo and drive matched to each other and ready
    to rock?
    Craig
    May 2011
    790
    to rock?
    Craig
    Do those drives accept step/dir inputs? What power input do they require? Do you have any links?
    Yes, it's worth it to figure out. I'm in Canada, compare CAD to USD, lol. Now multiply the difference by more than one axis. Everything is on a budget. Plus the servos I have are high quality, never been used. It's literally brand new stuff, even if it has sit in a package for a few years.
    Still, I'd appreciate your continued input while I figure this out .
    Nov 2013
    4358
    Yes, step/dir, CW/CCW etc, analogue velocity and analogue torque and every combination in between as befits a modern AC servo.
    They take 230VAC direct, no power supply required.
    If you don't like Delta (Taiwanese manufactured in China) then look at DMM (Canadian manufactured in China). The do two drives, the DYN2 which takes 75VDC or for a
    few extra bucks the DYN4 accepts 230VAC and is recommended. The higher voltage will ensure you get full rated speed.
    DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Both Delta and DMM are good brands that wont break the bank......there are cheaper Chinese no-name brands which work but don't enjoy the support that Delta and DMM do.
    Craig
    Nov 2013
    4358
    I didn't mean to suggest that the servos you have aren't worth trying to get going but rather because they are in effect 'orphans' you will have to adapt some drive to them.
    You could easily spend $200-$300 on a drive and STILL have some uncertainty that they will work. Whereas if you buy DMM and matching drive there is no uncertainty.
    It may well be you could sell the existing servos as 'new old stock' and let some other poor sap worry about trying to get the right drives.
    Craig
    May 2011
    790
    Thank You to everyone for all of your replies so far....
    Below is an addendum to the conversation that I have been having in another thread:
    https://www.cnczone.com/forums/stepp...186-cnc-2.html
    Moving it over here so I don't hijack that thread more than I already have.
    Quote Originally Posted by jfong View Post
    Try finding some drivers on eBay that work.
    You're right.
    My big problem is that I don't have a clue what in the heck I'm doing when it comes to servos. I can scour EBay for hours then look for manuals for things I find there, not find the manuals, look for something else, etc. The big thing about EBay is there's lots of surplus stuff that you can find good deals on (lots of way way overpriced deals too), but you need to know what you're looking for, and I don't.
    I'm like a child, or a neanderthal banging away at a rock with another rock. I need someone to hold me by the hand and say....hey, look to see if you can find a deal on any of the following drivers on EBay....which might work for you.
    Ideally, a surplus 4 axis servo driver accepting step/dir inputs with a 120VAC single phase power input is what I would like to find.
    One big thing I need to consider is that I still need one more axis (I have collected three so far). All 3 have the Tamagawa Seiki's. I have a line on a 4th that has the same motor...but it's a bit on the pricey side. So deciding on what I'm going to do here will affect the purchase of my last stage.
    May 2011
    790
    One thing I've been considering recently is to simply go with some JMC 400W servos. I'd need to make up a couple of adapter plates, not necessarily a big deal.
    https://www.aliexpress.com/item/4000067490526.html?
    Those would come in at just over $150 USD each, plus tax...and they have some good reviews online. That's probably around what it might cost me to get some drivers for the Tamagawa Seiki's IF I can find some.
    Encoder line: 1000 lines
    What does that mean?....from what I've read it usually means 1000 x 4 (quadrature?) but also I've read that for Chinese servos it can just mean 1000. And that would be distinct increments per revolution? So for a 20mm lead, 20/1000 = 0.02mm or 0.0007" best case scenario theoretical resolution on the servo? Is this correct or am I totally out to lunch here?
    Pulse Frequency: le250K
    Default communication rate: 9.6Kbps
    I'd need to make sure that the Duet 2 or Duet 3 can keep up with them. Haven't figured that out yet either.
    Any thoughts?
    Apr 2004
    733
    Normally when encoders are listed as 1000lines, it will be 4000 pulses per rev with 4x quadrature decoding.
    Several months ago I looked at the data sheets and manuals for the JMC and couldn’t get a reliable definitive answer to the encoder resolution. Several different manuals listed it differently. Best guess is 4000ppr. I’ve never used one so can’t say how good they are.
    Before buying any kind replacement servo, take the linear stage apart and measure the old servo shaft diameter. Make sure you get a servo with the same. Those couplers in the linear stage are very expensive high end versions and you want to re-use them again if possible.
    May 2011
    790
    I should probably send them a message and ask....
    Is 4000 ppr or even 1000 ppr a decent enough number for driving 20mm lead ballscrews?
    It will also be 20mm in the Z, but fully counterbalanced. I was thinking about using a 0.9 deg stepper for this originally if I could not get the Tamagawa Seiki servos working. Keep in mind, it's for a 3d printer.
    Ideally, I would use a 2:1 or 3:1 belt driven gear reduction...I could use the 180W servos if I did that....but I want to keep the servos inside the module housings, for simplicity, and because this would allow me to do forced air cooling on them in the future. So for the JMC, it would need to be the 400W as 180W direct drive on 20mm lead isn't good enough.
    The Tamagawa Seiki's have a shaft diameter of 11mm, while the JMC's have a shaft diameter of 14mm. Looking at the shaft coupler, it's some kind of fancy coupler with aluminum on either side, two set screws per side, and a polymer center (but not Lovejoy style, it doesn't come apart). I think I could easily drill out the 11mm on one half to 14mm and reuse it. I just have to check the dimensions of the adapter plate in CAD to double check if it will work with the JMC.
    Regardless, the JMC servos have long shafts, like the Tamagawa Seiki's, so finding a Lovejoy coupler that's a bit longer than the original coupler would be easy enough if I need to, to accommodate for the adapter plate. A standard Nema 23 has a shaft length of around 10mm shorter than the servos, so it's more problematic.
    I have figured out the pinouts for the encoders on the Tamagawa Seiki servos....the stages did come with a manual, and a diagram, and the wires are colour coded.
    Attachment 446950
    Apr 2004
    733
    I priced out those types of couplers and they are not cheap. Any of the very low backlash ones are pricy.
    Good that you have the pin out. All differential signal output which is very good.
    A,B,Z would be the incremental encoder outputs
    U,V,W are the hall sensors for each motor winding.
    There should be another connector which has three wires. These are the motor power input. Maybe also a shield 4th wire.
    Apr 2004
    733
    Always better to have the highest encoder ppr. Not so much for resolution but for better Servo performance. More ppr counts the driver has available, the more data to calculate PID and all that other fancy stuff. Makes the motor run smoother.
    20mm/1000ppr is 0.02mm or about 0.0008 inches. Is this good enough for a 3D printer, probably.
    A stepper motor is good for 2000microsteps per Geckodrive. Any higher is empty resolution.
    2000microsteps will sorta be better than a 1000ppr encoder. However the encoder will give very good evenly spaced steps. That’s not always the case with stepper motor. It could take a couple micro steps before a shaft actually moves. That depends on the load on the stepper motor shaft .
    Of course 4000ppr would be way better. Some of my servo motors have 8000ppr or even higher.
    May 2011
    790
    I wonder what the ppr is on the Tamagawa Seiki's?
    Yes, these couplers would not be cheap if you were to buy some. I would end up going with the standard EBay Lovejoy couplers at that point.
    Aluminum with a hard rubber center....I wonder how they make them...
    Attachment 446956
    Motor connection pinouts:
    Attachment 446958
    There are some internal limit switches...not sure how useful those are...kind of hard to adjust with the cover on
    Attachment 446960
    Attachment 446962
    Attachment 446964
    Attachment 446966
    May 2011
    790
    There are a few people using JMC servos with Duet boards...I'll have to look into it a bit more.
    https://forum.duet3d.com/topic/12126...xis-movement/2
    Nov 2013
    4358
    are you getting enough savings on the cheaper JMC's relative to a known good brand like Delta or DMM?
    My guess is you'll be paying 75% of the price of a Delta B2 series (160,000 counts per rev) for a JMC of the same power but way less
    quality and support.
    Craig
    Nov 2013
    4358
    by the way I bought a 400W Delta B2 series and then some 750W Delta B2 series, the price difference between the 400W and 750W was only $38USD.
    With 750W you probably don't need a belt or gear reduction.
    Craig
    May 2011
    790
    Craig
    All options are still on the table....right now my big thing is to figure out if I should try and ensure that I get another Tamagawa Seiki for my last stage that I haven't bought yet.
    Can you please post some links to the Delta B2 series, where would you buy that?
    I was looking at some DMM drivers to drive my Tamagawa Seikis. I wonder if these would work:
    DMM | NEW DYN2 AC Servo Drive | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Those are $218 plus tax / shipping for each driver, although it doesn't look like I'd need to buy power supplies, and I don't know if it would work.
    The JMC 400W servos are $108 USD plus tax / shipping (albeit shipping is more).
    Craig
    I don't need any reduction with a 400W (or even 300W), but if I did have some reduction I could get away with 180W, that was the point I was trying to make.
    750W is overkill for what I'm doing. Also, I don't think I could fit them in my stages. But that's good info to know.
    I'm really kind of hoping that some one will come along and say, hey, you know what, the following 4 axis servo amp will accept step/dir inputs, and probably work out for you, and I can find that on EBay, surplus, and not for a kidney.
    Lots of people like the JMC servos....but it appears that most of them speak German, making it difficult to understand what they're saying on YouTube.
    https://www.youtube.com/watch?v=xyVr35pgx7s
    As always, all feedback is appreciated!
    Nov 2013
    4358
    quite frankly buying a drive made by one manufacturer to operate a servo made by another is a risk I would not take. Are you going to save enough
    money to make the risk that it doesn't work worth it? I don't like spending money any more than anyone else, but what really pisses me off, is when I spend
    some money, even modest amounts, but it doesn't work out.
    I bought from:
    fasttobuy2012 | eBay Stores
    I paid $460USD including super fast 3 day DHL to New Zealand for a 400W Delta B2 series, and then a couple of months later $498USD again with 3 day DHL
    to New Zealand for 750W Delta B2 series. That is the drive (230VAC input), servo and cables ready to rock. It pays also to buy a programming cable, you can
    program the drives by pushing buttons but to use the genuine Delta programming software is the only real way to go. You only need one programming cable
    and you can program any number of A2's,B2's,A3's or B3's you have.
    Since I bought them fast-to-buy have emailed me with offers at even better prices, they have been offered even greater discounts by Delta on the basis of annual sales.
    They offered me a 400W B2 combo for $380USD including shipping. For that price why would anyone consider the even cheaper no-name brands?
    The B2 series have a 160,000 incremental encoder.
    The A2 series have a 1,280,000 incremental encoder and load sensing, so you could use a linear scale AND the normal rotary encoder......super kool!!!
    The A3 series has a 24bit absolute encoder, and I think the B3 series has a 24bit multi-turn absolute encoder, the B3 series is the latest kid on the street.
    Craig
    15362
    Quote Originally Posted by NIC 77 View Post
    The Dmm servo drives will not run the Tamagawa Seiki servo motors and there will be very few that would be able to run them if any without some reconfiguration
    Mactec54
    24220
    I really like Tamagawa motors, I have picked them up quite cheap off ebay etc, and used them with a few systems. but the BLDC drives I have used are the simple torque mode amplifiers where the loop is not closed in the drive.
    Various manuf.
    Very simple to use where the servo loop is controlled in the main controller and not the drive.
    The problem comes when systems such as Mach is used.
    Al.
    Albert E.
    24220
    BTW, one decent place for CNC hardware, couplers etc, is Misumi.
    The free catalogues they send out free , or used to, are worth it for the mechanical reference information.
    Al.
    Albert E.
Page 1 of 3 123
  1. Two servos on one drive?
    By protman16 in forum Servo Motors / Drives
    Last Post: 05-29-2008, 07:23 PM
  2. Baldor Servos And Drive
    By Cycle Start in forum Servo Motors / Drives
    Last Post: 05-29-2007, 01:28 PM
  3. Will Geckos drive these servos ??
    By jsatter in forum Gecko Drives
    Last Post: 06-28-2006, 06:29 PM
  4. Direct drive servos
    By pstockley in forum Servo Motors / Drives
    Last Post: 04-27-2006, 02:01 PM
  5. Servos and drive help
    By tdpyro in forum Servo Motors / Drives
    Last Post: 03-14-2005, 06:35 PM
