2020 Best 4 Axis CNC Router 1325 with 4x8 Rotary Table
4 axis CNC router machine with rotary table adopts DSP A18 4 axis control system, it can achieve X axis,Y axis, Z axis and A axis work at same time. It is one really 4 axis CNC router.
There are 4 axis linkage CNC routers and 3 axis linkage CNC routers for choose.
If you work just need to do the cylinder carving, 4 axis with 3 axis linkage is enough, if your work asymmetrical or square, it need 4 axis 4 linkage (real 4 axis). For example, if you want to do one buddha, the 3 axis and the 4th axis can't finish it.
Compared with 3 axis and 4th axis CNC router, 4 axis 4 linkage CNC router can read more complex G code, 4 axis CNC router G code need to use the professional 4 axis software.
4 Axis CNC Router
STYLECNC is a guaranteed manufacturer for CNC Router, Laser Cutter, Laser Marker, Laser Engraver, Wood Lathe and Plasma Cutter. Official website: https://www.stylecnc.com/
