585,886 active members*
5,418 visitors online*
IndustryArena Forum > CAM Software > MadCAM > setup for tilted 4th axis in MADCAM - Additional question
Results 1 to 2 of 2
    Apr 2018
    14
    Since I am getting no replies about my previous thread I will post a new one. Does anyone know if MADCAM/Mach3 4 axis postprocessor support G93 (inverse time) generation of G code? This appears not to be present in the "stock" mach3 4 axis postprocessor in MADCAM. The problem is that I need to have separate feed rates for X,Y,Z and A axes else the A axis runs at very low feedrate. Mach3 and Mach4 programs can accept G93 but if the postprocessor does not calculate F (feedrate) at every line with a G01 command the feedrate needs to be entered manually, clearly impossible. So the G93 federate needs to be calculated and inserted into the Gcode by the post processor.
    Somehow I seem to be asking impossible questions...
    JRS_CNC
    Apr 2018
    14
    Re: setup for tilted 4th axis in MADCAM - Additional question
    OK, I was able to write a PP for MADCAM, using the help section, that creates good Gcode using G93 that Mach3/4 can use. Apparently everyone knew this already...
    JRS_CNC
  1. MADCAM 4 axis setup
    By JRS_CNC in forum MadCAM
    Last Post: 06-01-2020, 06:07 PM
  2. setup for tilted 4th axis in MADCAM
    Last Post: 02-05-2019, 08:44 PM
  3. setting 4th axis tilted for clearance
    By cruizer67 in forum CamWorks
    Last Post: 10-18-2018, 07:04 PM
  4. 4 axis setup question
    By jeanyes in forum MadCAM
    Last Post: 07-08-2013, 08:04 PM
  5. Replies: 2
    Last Post: 03-12-2012, 12:21 AM
