584,858 active members*
4,528 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc om-c ladder diagram ( trying to get DNC )
Results 1 to 2 of 2
    Sep 2019
    15
    I have a mill with fanuc om-c . I would like to activate the DNC function . The machine dose not have a tape mode switch or any switches in the cabinet to activate it . There dose not appear to be a G127.5 on the ladder
    but I have 4 reserved M codes and one has a 1275 associated with it .
    Can someone with some ladder knowledge tell me if this can be used to turn on dnc or is the 1275 just a coincidence just to send me down a rabbit hole ?
    Attached Thumbnails Attached Thumbnails 8DC58174-A85C-40E2-BB13-2690FEFBD2E1.jpg   8DD21C0E-DC19-42E9-A46A-3D17AC9A4695.jpg
    Dec 2009
    947
    Re: Fanuc om-c ladder diagram ( trying to get DNC )
    you are wrong
    that numbers where is also 1275 are the net numbers where that Y adress is used so you can follow easy on the diagram,has non to DNC
    As far as i know if there is not G127.5 in the ladder ,you have to create it and use a diagnose bit number or an M code to enable it.
    Good luck
    PS:and if you are the guy who made the photos ,that is not the way we share info here,hiding from who,or what is that to be hidden?
    Are equations from NASA space ships?
  1. Moriseiki SL6 Ladder Diagram - Fanuc 6T
    By gowthu in forum Fanuc
    Last Post: 05-29-2022, 09:48 AM
  2. FANUC Ladder Diagram Address
    By aryagunaputra in forum Fanuc
    Last Post: 08-09-2015, 11:33 PM
  3. Fanuc 11m Ladder diagram
    By Selimsalim in forum Fanuc
    Last Post: 05-22-2012, 05:40 PM
  4. Fanuc 16T Tornos ENC-167 ladder diagram
    By Jung in forum CNC Swiss Screw Machines
    Last Post: 11-19-2010, 08:49 PM
  5. LADDER diagram Fanuc OT
    By tano in forum Fanuc
    Last Post: 09-06-2010, 03:58 PM
