585,970 active members*
4,157 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > z axis mini mill, cutting in between ways?
Results 1 to 6 of 6
    Jul 2018
    58
    So far I have added the z axis ballscrew on the side of the mill, however I have noticed an irregular movement. It seems that when the machine is moving down it applies pressure to the left, causing a slight tilt and the opposite happens when moving up. I know this can be corrected by tightening the shim between the ways. I was thinking of cutting a slot between the ways but I am a little concerned about causing stress fractures or cracking the casting with use. I think attaching it this way would not cause this irregular tilt . Any thoughts on this?
    Attached Thumbnails Attached Thumbnails 101029749_247665376485514_2924990144391938048_n.jpg   83057897_282649226109599_8712079789701201920_n.jpg   101538135_269438840916382_7563453054821859328_n.jpg   79502584_715705045871813_7418070864278585344_n.jpg
    Jul 2018
    58
    I wanted to say thanks to (nobody) for all the input , I ended up cutting between the z axis ways
    Jan 2008
    1529
    Re: z axis mini mill, cutting in between ways?
    I suspect people didn't understand what you were talking about (I didn't).
    How does it perform now?
    Jul 2018
    6337
    Hi CRL - You do need to be more precise with your questions to get an answer. In #1 yes you just adjust the gib (shim) to remove play in the way. But you have moved the drive to central but you still need to adjust the gib. Did the mod work? Peter
    May 2005
    1662
    Sometimes there are no responses because no one knows the correct answer. My gut feeling is little structural integrity has been lost but someone skilled in FEA software can answer without depending on intuition.
    The weakest part of the tilting mini-mills is the base-to-column connection. It takes only a small amount of pressure on the column to get deflection, a brace helps a lot.
    Anyone who says "It only goes together one way" has no imagination.
    Jan 2018
    1516
    I did the solid column upgrade on mine and machined it a little to get 150mm on the Y axis.
    Rigity was miles better.
    I had the same twist action on my head driving down the side. A double nut may have made a difference.
    The downside with slotting out the center is you won't be able to use it as a manual drill again as the rack teeth will no longer attach.
    I never really liked the machine as a cnc that much in the end.
    The small table vibrates and twists all over the place.
    Was made worse by opting to build it using thrust bearings and not angular contact ones.
    I upgraded to a PM25 type machine as soon as I could.
  1. box ways for pcb mill z axis
    By jschoch in forum PCB milling
    Last Post: 01-14-2019, 04:52 AM
  2. Sieg X2 Mini Mill CNC machine not cutting concentric (pictures)
    By neurotoxin312 in forum Benchtop Machines
    Last Post: 02-18-2014, 04:34 PM
