584,865 active members*
4,913 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > K2CNC > KT-2514: Move from Mach3 to Mach4-Hobby and Windows 10 Pro
Results 1 to 6 of 6
    Dec 2019
    13
    I have owned a KT-2514 for a while but have always been hobbled with all sorts of instability and obsolescence issues with the parallel port.
    I have decided to move on to Mach4 and to connect the KT-2514 with my Dell T7500 running Windows 10 Pro.
    I need help with identifying what hardware to buy; Is it possible to get something based on USB 2 or USB 3? Could I get something to replace the control box or am I stuck with the parallel port connection.
    All help appreciated.
    Thank you.
    Re: KT-2514: Move from Mach3 to Mach4-Hobby and Windows 10 Pro
    Get either an Ethernet Smoothstepper, a UC400ETH, or a UC300ETH motion controller.
    Just plug the cable that went to your parallel port into the controller.
    You don't really want a USB controller, the ethernet ones are much better.
    Dec 2019
    13
    Thank you so much Gerry!
    I'm on it.
    Dec 2019
    13
    I have the UC400ETH on order from Amazon and will give UCCNC a try.
    Thank you once again.
    Question Re: KT-2514: Move from Mach3 to Mach4-Hobby and Windows 10 Pro
    Hi Omorali
    I have a KT-2514 servo machine. I recently had to reformat the hard drive on the computer I was running Mach3 and lost the settings in Mach3. Do you have a KT-2514 profile you can send me? Thank you.
    Jerome
    Dec 2019
    13
    Hello Jerome.
    I apologise for reverting this late; I just logged on.
    Do you still have this requirement? It is my pleasure to share with you.
  1. MACH3- windows xbox wireless - windows 10 64bit plugins not working
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-02-2018, 04:48 AM
  2. Omiocnc / yoocnc with mach4? Windows 10?
    By brentj in forum Chinese Machines
    Last Post: 03-03-2017, 07:06 PM
  3. Replies: 2
    Last Post: 12-06-2011, 12:45 AM
  4. move operation windows out of the work area
    By Kochy in forum Uncategorised CAM Discussion
    Last Post: 07-15-2011, 07:42 AM
