585,883 active members*
4,674 visitors online*
IndustryArena Forum > CAM Software > Vectric > Surfacing onsrud router table
    Jan 2019
    5
    I have no idea how to surface my osrud table. I'm use to running multicam routers. Which is pretty easy to surface. I have very little training with this osrud table.
    I have no idea where to start, So any help would be greatly appreciated!!!
    How do I set the height on my MDF?
    C.R. Onsrud M series model # 4100M12
    Using a OSAI controller
    Vcarve Pro
    Thank you,
    1222
    Re: Surfacing onsrud router table
    I just found this post and sympathise with the problem.The best solution I found was to use the pocket feature and to create a vector,just a touch larger than the spoilboard, to indicate the boundary of the cut.Then just create a pocketing routine to the shape and desired depth.It worked for me.
  1. NEE - AMC Control on Onsrud Router
    By MarkT in forum Commercial CNC Wood Routers
    Last Post: 12-18-2023, 08:07 PM
  2. Onsrud CNC router Z offset
    By roobox in forum Commercial CNC Wood Routers
    Last Post: 05-07-2020, 07:28 PM
  3. C.R. Onsrud table fixture or kurt vice.
    By nottoshabbie in forum CNC Machining Centers
    Last Post: 04-12-2017, 08:39 PM
  4. surfacing router table
    By lumberjack_jeff in forum LinuxCNC (formerly EMC2)
    Last Post: 09-01-2009, 03:41 AM
  5. Onsrud Overhead Router
    By marksnwv in forum Open Source CNC Machine Designs
    Last Post: 11-18-2006, 06:18 PM
