585,708 active members*
3,899 visitors online*
    T32-3 no M commands after reinitialization
    Hello,
    I have this problem. After we lost parameters due to a faulty battery I did a reinitialization procedure for T32. I pulled parameters from the eeproms, Cleared all the areas to finally start the machine without any alarms, BUT I could not send home, SO I had to re-establish the home position with an instruction manual that I downloaded from the mitsubishi website. FINALLY, after numerous attempts the machine made it to the home position.
    NOW, MY PROBLEM NOW IS I can not get the chuck to open and close AND I can not turn the coolant ON and OFF in MDI mode. The chuck works fine in manual mode
    Any ideas?
    Thanks for the help
    jolulank
    www.doctornumerico.com
    cnc physicians
    Jan 2019
    Re: T32-3 no M commands after reinitialization
    Parameter R49
  1. T32-2 reinitialization procedure parameter retrieve
    By jolulank in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-26-2017, 04:52 PM
  2. T32-2 reinitialization procedure parameter retrieve
    Last Post: 09-24-2013, 05:27 PM
  3. Who gives commands here?
    By Take-it-easy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-22-2011, 10:25 PM
  4. Dos Commands
    By LYN BYRD in forum Milltronics
    Last Post: 08-01-2011, 04:21 PM
  5. G2 and G3 Commands
    By Bohemund in forum G-Code Programing
    Last Post: 05-28-2007, 03:12 PM
