585,981 active members*
4,470 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Remax 1325 - CNC Wood Router - Brand New - Spindle Motor Not Running - Error E004
    I recently imported 1325 CNC Wood Router from China, all stepper motors are working fine except Spindle motor. It refused to spin so i checked the fuling inverter and there was this error message E004 displayed. I scouted the internet for solution and found that acceleration time F0.08 has to be increased to 15 or 20 on Fuling Inverter. Even after increasing the timing i couldn't get the motor spin. I could hear motor wanted to start but then after the number in Fuling inverter display reached around 36 it stoped and error E004 displayed.
    Has anyone come across this issue and how did you get around the problem? Kindly help. Really stuck. Chinese seller is not helping either.
    Regards
    Arun
    Re: Remax 1325 - CNC Wood Router - Brand New - Spindle Motor Not Running - Error E004
    Hi friend
    our company also use fuling inverter,the alarm E004 means that the spindle is overcurrent during acceleration, which is usually caused by the short circuit between the spindle and the frequency converter.
    My suggestion is to check whether the connection between the spindle and the frequency converter is short-circuited. If there is no short-circuit in the external wiring, the possible reason is that there is a short-circuit in the internal circuit of the spindle.
    Hi Guys, Any of you have the manual for this 1325 Machine? Thanks
  1. 1325 3 spindle wood cnc router machine 4 axis for wood furniture carving
    By BlueElephantCNC in forum News Announcements
    Last Post: 12-02-2019, 09:21 AM
  2. Blue Elephant 1325 4 axis wood carving router for wood acrylic metal
    Last Post: 11-18-2019, 10:25 AM
  3. 1325 3 spindle cnc wood router machine for wood door making
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 10-23-2019, 09:44 AM
  4. 4.5KW spindle motor CNC router for wood
    By SPC-laser in forum News Announcements
    Last Post: 08-15-2012, 06:41 AM
