585,712 active members*
4,092 visitors online*
Results 1 to 6 of 6
    Question Novusun EC500 Mach3 no Spindle output
    I am just retrofitting a lathe and am using a Novusun EC500 controller.
    https://www.nvcnc.net/ec500.html
    The output for pwm and also digital out 1 and 2 for cw and ccw won't have any signal.
    I configured it following the manual, but still without success.
    I also tried different setups different pins. No success.
    GNDS and VSO for the 0..10V input at the Vacon NXS drive
    com- and OT1 CW OT2 CCW
    Ports and pins
    Motor outputs
    Spindle enabled / StepPin 1 / DirPin 0 / Step LowActive / Step Port 1 Dir Port 0
    Spindle Setup
    CW Output 1 / CCW Out 2 / Use spindle outputs / PWM Control / Base 5 / Min 0 /
    Output Signals
    Out 1 enabled / Port 2 / Pin 1 / Active Low
    Out 2 enabled / Port 2 / Pin 2 / Active Low
    I can not measure any output at the connectors.
    Thanks for your help...
    Nov 2013
    4358
    Re: Novusun EC500 Mach3 no Spindle output
    if you go to the Mach Forum you'll be told that Novosun is on the blacklist because they peddle pirate Mach3 liceneses
    and you'll get no help.
    If you want support get a different controller like an Ethernet SmoothStepper or a UC300.
    Craig
    15362
    Quote Originally Posted by abc123456789 View Post
    Ports and pins
    Motor outputs
    Spindle Setup
    Output Signals
    No you can configure it for PWM output, you want to configure it for 0-10v not PWM
    I would say your problem is that your Ports and Pins in Mach3 don't match with the Novusun
    You can't use PWM output to control the VFD Drive although some VFD Drives can take a PWM signals most only have 0-10v as the main input for speed control
    Mactec54
    Very helpful reply.
    I have a legal license purchased.
    I am having already one machine with the same Vacon Drive. PWM works perfectly on the 0..10V input.
    Unfortunately the manual is not very clear.
    I will try the pinsetup today again.
    Feb 2010
    69
    Hello abc123456789!
    Did you receive a cd with this control?
    I'm looking for a .bin file to reset the firmware on mine
  1. novusun v2 4 axis 200hz ,help on setup spindle
    By magnetos2010 in forum Controller Cards
    Last Post: 03-26-2021, 07:54 PM
  2. Novusun NVUM controller + Spindle help
    By charlierj in forum Spindles / VFD
    Last Post: 01-14-2020, 04:48 AM
  3. Motors won't turn but they are locked!(Workbee CNC, MACH3, Novusun Controller).Help!
    By cncnoob67 in forum Mach Software (ArtSoft software)
    Last Post: 03-29-2019, 02:09 PM
