584,866 active members*
4,940 visitors online*
    HSM Linear problem
    i use the HSM Linear Operation for a specific part and i have celected all the faces i want ( picture ) and i use stepover 5.2mm but it keeps the same line of pass for all the different faces as it is in the picture . but the faces i have sellected have a zig-zag patern so as the operation uses the same"line; i find mi self haveing different passes on the left surfaces than on the right surfaces . hope the pictures help
    is there a way to have different stepovers etc for every one of these geometries ? i use SOLIDCAM 2018
    HSM Linear problem
    Hi
    Is it possible when using HSM Linear Operation in solidcam to select diffrent passes for every different face in the same operation ?
    thank you !
    Nov 2012
    45
    Re: HSM Linear problem
    Quote Originally Posted by Alexpaintkiller View Post
    use only for 3D shape liniar.....in your case only 2D strategies!SIMPLY!
  1. Replies: 1
    Last Post: 11-24-2017, 03:56 AM
  2. Linear scale & feedback problem
    By ahmed4040 in forum Fanuc
    Last Post: 08-09-2017, 07:33 PM
  3. Linear bearings and steppers problem
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 07-20-2010, 03:54 PM
  4. Linear Rails - What is the problem
    By kimfmx in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 02:37 PM
  5. Linear bearing problem
    By ranchak in forum Linear and Rotary Motion
    Last Post: 10-09-2007, 03:42 AM
