Hi, Im looking for a router bit for EPS, Poly foam and soft wood (Balsa and Basswood) .I hope some one can point me to the right place.I can find small bits but no big bits I attached a link to a picture of the bits
im looking for. Here are the specs.
CUTTER HEAD DIMENSIONS: 1.22" (31mm) Diameter X 2.83" (72mm) Length.
SHAFT/SHANK DIMENSIONS: 1/2" Diameter X 1.5" (38.1mm) Length.
This cutter is also suited to any CNC Machine that takes A 1/2" Shank
I cant find any one in the US that makes this size of bit.Thank you
for your help.
Mark
