585,604 active members*
3,419 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > No Spindel Start M03 M04 and no Errors
Results 1 to 6 of 6
    Hi
    I have a Leadwell milling machine 3 axis vertical Fanuc 18MC
    The operator accidentally deleted the parameters.
    Backup no longer exists only the parameter book where is also complete.
    After entering parameters 100 - 9999, all errors that occurred were eliminated.
    The control panel is working again, axes 3 are running again, no errors can also be moved to the reference point, tool change is working. The other parameters such as D, K, T were also included
    typed with the greatest care and checked 3 times.
    The only thing that doesn't work is the spindle !!
    After command for spindle start e.g. S200 M03 nothing works !! Also M04 !! or other speed
    Even if I specify a speed including axis movement, this sentence is without errors
    processed even when the spindle is stationary !?
    It is strange that the spindle orientation runs and executes it.
    No error message on the spindle controller?
    On the display on the controller 00 is therefore energized and without errors.
    View does not come up with an error message.
    When I try to turn the spindle in this state, the spindle keeps turning back.
    Does anyone have an idea?
    thanks in advance
    Re: No Spindel Start M03 M04 and no Errors
    Did you restore the PMC parameters as well. The timers, counters and keep relays?
    Jun 2020
    5
    I have a leadwell MCV-OP, I have a safety switch on the spindle cover, if that isnt pushed in correctly my spindle wont spin, but will orient.
    I wonder if there was a parameter to disable yours if its not working, or something similar with an interlock for the spindle.
    Hello
    Have no Backup from the Maschine only the Parameter Book from Leadwell.
    Yes i wrote all Parameter in the Conroller inc. all Timers,Keep Relais and Counter
    i Think all is Correct but not Working
    Hello
    I will check it
    is a Leadwell MCV-1300P
    thanks
    "I have a leadwell MCV-OP, I have a safety switch on the spindle cover, if that isnt pushed in correctly my spindle wont spin, but will orient.
    I wonder if there was a parameter to disable yours if its not working, or something similar with an interlock for the spindle."
    Quote Originally Posted by uensalistig View Post
    Hello
    Hello
    I check the switches , that's not the problem
    But thank you
