Originally Posted by
John Roberts
Hi Cliff, the LED style tool height setter might take a few more seconds. Move the tool down till the light comes on, move it up till the light goes off, then jog it down till the light comes on again. Done. One can also feel the resistance on the tool against the spring by jiggling the setter sideways as a double check. It works for me and probably many others.
I have not had any issues using this method. The platform on my setter is only 1/4" dia. Most of my tools I use are smaller than 6mm but on larger cutters I just come down on one flute of cutter without noticing any accuracy issues.
On the mini dial indicator that you are converting, I am not sure if it is necessary to have a dia platform as large as your blue setter? How are you going to maintain a fixed height on your setter. Can you lock the dial or have you other plans!
