585,974 active members*
4,304 visitors online*
Page 3 of 3 123
Results 41 to 47 of 47
  1. #41
    Dec 2008
    740
    Re: What ToolSetter do you use?
    Quote Originally Posted by keen View Post
    I know the early Renishaw toolsetter was based off its probe design, (yes the "Renishaw 3-ball/6-cylinder kinematic restraint mechanism that is often used in touch probes?" ) but they may have advanced past that now. Not sure.
    I'd been considering a Tormach ETS for quite some time and watched the price hike from under $800 to $1295 - it all went pretty quick too! I also tried a cheap ebay ETS but also found the quality far too poor. Finally I picked up one of these on ebay:
    Attachment 445220
    It's the older design but absolutely unused. A little over-the-top for a Tormach? Well not really, it cost me LESS than the pre-hike price of the Tormach ETS!
    The head rotates inside the black body and adjustment screws on the base both combine to allow the top of the head to be aligned with the machine. It has a replaceable "break stem" between the body and the vertical head to protect the probe against crashes (I bought a couple of additional replacements). Obviously this has capabilities beyond those of a simple ETS but they're not really much use on a Tormach, but that won't stop me playing around . I haven't actually tried it yet due to other priorities but I'll get around to it in the next week or two.
    Step
  2. #42
    Apr 2013
    1788
    Nice! Any idea of the internals? Is it just a normal Renishaw MP3 turned on its side or something fancier? How do you adjust the test platform to be horizontal? Are the "break stems" the usual Renishaw 4mm male/female ceramic pieces or...?
  3. #43
    Feb 2007
    1538
    Quote Originally Posted by John Roberts View Post
    Hi Cliff, the LED style tool height setter might take a few more seconds. Move the tool down till the light comes on, move it up till the light goes off, then jog it down till the light comes on again. Done. One can also feel the resistance on the tool against the spring by jiggling the setter sideways as a double check. It works for me and probably many others.
    I have not had any issues using this method. The platform on my setter is only 1/4" dia. Most of my tools I use are smaller than 6mm but on larger cutters I just come down on one flute of cutter without noticing any accuracy issues.
    On the mini dial indicator that you are converting, I am not sure if it is necessary to have a dia platform as large as your blue setter? How are you going to maintain a fixed height on your setter. Can you lock the dial or have you other plans!
    Hi John. I see, you pass though it and back up you find is quick. Makes sense.
    Re indicator fixed height design. Just at the research stage, a few options up in the air. Fixed buttons either side or a plunger lock, or maybe a movable block underneath.
    Cheers Cliff
  4. #44
    Nov 2007
    2151
    One more ets strategy not covered above but useful to understand for many manual collet tool change users "routers"
    This is the unit sold with the 24r system. The touch off button / plunger does not appear to move or wiggle much at all. Using PP all my router programs return to the e.t.s. and touch off in the same spot every time. No special setup just follow pp prompts. After completing those steps the actual height of trigger point is determined and set as a stored value.
    Attachment 445260
    Note plastic location ring at base of e.t.s. This is used to locate the e.t.s at same location on router table if you move it to clean. Also the ets can be moved and used to set g54-g59 ucs z height by setting ets on desired work surface and touching off.
    Attachment 445262
    This is another way to set u.c.s z offsets in addition to more normal methods like direct tool to work surface with feeler guage.
    I also keep a small guard to and "cover in background" to keep ets cleaner during use. The round guard also acts as a platform for manual tool changes when prompted during a program.
    Attachment 445264
    The ets for setting tool heights and part z offset height combined with a electronic-probe for finding part x-y offset edges makes a decent accurate system for this type of machine and collet held tools.
    Also the machine has dedicated ports for both tools to make it easy to use.
    Attachment 445266
    Hope this helps others with this concept.
    Sorry no music machining videos
  5. #45
    Nov 2007
    2151
    Edit above post:
    The ets can be moved and used to set g54-g59 ucs z height by setting ets on desired work surface and touching off.
    First set a tool number, then measure that tool. then move ets to z work surface. Move tool over ets and go to work offsets page. select work offset and press button on right set z offset. This will automatically measure the height from surface with ets and subtract the touch off height of the ets. Very fast repeatable way to set z work offset with an ets and no need to jog z down to a feeler guage.
  6. #46
    Nov 2007
    2151
    Just for reference
    Tormach just posted a video showing the above ets using the strategy I mentioned above to set z part offset. Then used ets to set tool heights for rest of program normally.
    https://youtu.be/QT5HSfPUcC8
  7. #47
    Feb 2007
    1538
    Thanks for those posts. Cliff
Page 3 of 3 123
  1. Doosan toolsetter
    By dcrace in forum Daewoo/Doosan
    Last Post: 03-29-2016, 03:06 AM
  2. Toolsetter
    By nitewatchman in forum Tormach Personal CNC Mill
    Last Post: 04-28-2013, 01:25 AM
  3. Toolsetter calibration
    By Positron20 in forum Turning Machines
    Last Post: 01-21-2010, 12:07 AM
  4. Toolsetter Adjustment
    By JHECNC in forum Daewoo/Doosan
    Last Post: 03-18-2009, 12:54 AM
  5. Where NOT to put your toolsetter.
    By behindpropeller in forum Haas Mills
    Last Post: 02-22-2009, 02:11 AM
