585,973 active members*
4,213 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Power supply max current rating
Results 1 to 5 of 5
    Jun 2020
    9
    I can't figure out the max current rating for power supply when I use 4 stepper motors linked below.
    What would be max current rating for 1 motor?
    What would be the max current rating for 4 motors?
    https://robokits.co.in/automation-control-cnc/leadshine-motor-drive/hybrid-servo-motor-2-phase-85kg-cm-w-t-es-d1008-leadshine-drive?cPath=75_138&
    Thank you all.????
    Aug 2005
    1092
    Re: Power supply max current rating
    The specification on that link says 4.2 amps per motor. 4 motors would be 16.8A
    Then multiply that by 2/3 = 11.2A total.
    A power supply like this should be ideal.
    https://www.homanndesigns.com/index....roducts_id=288
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Jun 2020
    9
    Thank you Peter. That's really great. Now I understand what to do. Thanks
    Jan 2018
    1516
    I'm not too convinced about running those nema 34 motors with as much as 4.4mh inductance on only a 48v supply. Want 60v at least.
    There's a reason the supplied drivers are capable of upto 100vdc.
    Look at AC toroidal supplies too (around 60Vac) as the drives can also take upto 70Vac direct.
    Or these type supplies can be rectified to supply DC.
    I've never done one (yet) but there is plenty of information on this out there.
    A quick example:
    https://electro-dan.co.uk/electronics/wiringtrans.aspx
    AT have pre built ones too. This is a 72Vdc:12A.
    https://www.automationtechnologiesin...5-w-duplicate/
    Jun 2020
    9
    @dazp1976
    I will look for some toroidal supplies. Thanks. The current rating I would be looking for would still be 11.2A right?
  1. Power supply current rating
    By Georgie in forum Benchtop Machines
    Last Post: 10-23-2014, 08:04 PM
  2. Fuse rating in power supply
    By dominicburke200 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-03-2010, 01:41 AM
  3. power supply sizing vs. servo rating
    By Erick Davidson in forum CNC Machine Related Electronics
    Last Post: 06-06-2006, 09:08 PM
  4. Gecko power supply 2/3" current rating?
    By JFettig in forum Gecko Drives
    Last Post: 01-06-2005, 03:04 PM
  5. Is this power supply rating adequate?
    By jerryrigge in forum CNC Machine Related Electronics
    Last Post: 11-25-2004, 05:06 PM
