586,009 active members*
4,893 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Remachining issues
Results 1 to 5 of 5
    Dec 2011
    97
    Remachining issues
    A few issues in Re-machining:
    1. If I select a previous cutter which is a flat end mill, the previous cutter Radius is populated as if it is a ball end mill. So if I select a 0.250 flat end mill, Radius is populated with 0.125 instead of 0.
    2.Overlap doesn't have a sensible default value.
    3. When I select a cutter, previous cutter dimensions default values change to values which are not standard cutter sizes. Maybe previous cutter dimensions shouldn't even be changed when I change the current cutter.
    4. When I remachined a part with an area which the previous cutter couldn't reach, it is not cut by the new smaller cutter which is able to reach the area.
    Dec 2011
    97
    Re: Remachining issues
    #4 may be a result of my not understanding how re-machining works.
    For example, all the re-machining operations except re-roughing ask for the previous cutter. I don't understand why re-roughing doesn't need to know the previous cutter. And the results I get from re-roughing don't make sense to me - it looks like there are cuts in areas which shouldn't have them.
    Maybe I have the wrong model of the machining sequence to use. What I have in mind is:
    1. Roughing, and then z-level, planar and pencil finishing with a large cutter.
    2. With a smaller cutter re-machining z-level, planar and pencil.
    Am I thinking about this in the wrong way?
    Dec 2011
    97
    Now I understand that re-roughing is based on the visible layers. With that information, I see two issues:
    1. If a layer was machined with a flat end mill, re-roughing mistakenly assumes that is was a ball end mill.
    2. Re-roughing with a smaller cutter does not cut a channel which the larger tool couldn't cut in the previous operations (which are visible).
    Aug 2009
    1573
    ...might help if, we knew what Cad/Cam system you're using.
    Dec 2011
    97
    madCAM 6
  1. remachining of old Mold Block
    By masks35 in forum GibbsCAM
    Last Post: 02-14-2012, 09:04 PM
  2. Remachining removing too much material
    By mspaw in forum MadCAM
    Last Post: 07-20-2011, 11:32 AM
  3. Remachining settings question
    By SScnc in forum Mastercam
    Last Post: 05-28-2009, 04:11 AM
  4. Remachining
    By johny0407 in forum Mastercam
    Last Post: 05-21-2009, 01:34 PM
  5. Remachining
    By MagTDK in forum MadCAM
    Last Post: 12-17-2006, 12:36 PM
