A few issues in Re-machining:
1. If I select a previous cutter which is a flat end mill, the previous cutter Radius is populated as if it is a ball end mill. So if I select a 0.250 flat end mill, Radius is populated with 0.125 instead of 0.
2.Overlap doesn't have a sensible default value.
3. When I select a cutter, previous cutter dimensions default values change to values which are not standard cutter sizes. Maybe previous cutter dimensions shouldn't even be changed when I change the current cutter.
4. When I remachined a part with an area which the previous cutter couldn't reach, it is not cut by the new smaller cutter which is able to reach the area.
