585,991 active members*
5,168 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Basic 3d tool entry in Enroute 6
Results 1 to 2 of 2
    Hi all,
    New member, and relatively new to CNC machining (so apologies in advance if I'm asking a rookie question, or if this has already been covered already... but I had a look through older threads and couldn't find an answer).
    I'm using a Multicam dual function tangential/oscillating knife, and regularly switch between a straight blade and a 45 degree knife to cut through a felt-like PET panel.
    Trying to ramp into the cut (using a 45 degree knife head) at an arc along the Z axis (so that it slopes gradually into and out of the cut) - but I can only find the toolpath setting to ramp into the cut along a 2D path.
    I understand that this will be difficult for a 45 degree knife to achieve, but I would also like to potentially be able to the same on a straight knife.
    I'm not sure if my version of Enroute 6 will allow this at all (it's the basic version), but any advice will be much appreciated!
    Re: Basic 3d tool entry in Enroute 6
    Update - according to the team that sold our Enroute licence with the CNC knife, there isn't a way to program this toolpath in the basic version of Enroute.
    Seeing as this function is designed for use with routers, the support team is going to test it with a 45 degree knife for me, and if it works I will evaluate and look into upgrading Enroute...
    In the meantime I'll post any updates here - hopefully this might help someone with similar questions.
  1. Replies: 3
    Last Post: 07-26-2019, 04:06 PM
  2. entry point for tool path
    By lovely123 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-21-2015, 01:34 PM
  3. Enroute 3 basic lost drill centers function
    By japco43 in forum EnRoute
    Last Post: 09-22-2011, 04:04 PM
  4. Replies: 1
    Last Post: 07-05-2009, 04:04 AM
