585,733 active members*
4,895 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > On average, how accurate has your Tormach been?
Results 1 to 16 of 16
    Jul 2015
    12
    Hello,
    I've been looking into Tormach for prototyping parts in brass and aluminum. I was curious what kind of tolerances are you holding with the Tormach or how close are coming to your desired measurements?
    Thank you for feedback.
    Mar 2020
    218
    Re: On average, how accurate has your Tormach been?
    Haven't really tried too hard to maintain accuracy with mine yet, mostly because the parts I've been making are more experimenting with tools and materials than actual parts I need. That said, ±0.005" has been the norm without trying at all. Adding a spring pass to my finishing ops has gotten me within a thou or two. I believe my biggest issue with accuracy is my tooling and my own lack of experience with machining.
    Jul 2015
    12
    Thanks, can I ask what model you have?
    Oct 2010
    670
    +/- .005" with ease, +/- .0025" with some wear comp settings and watching parts, +/- .001" - can be done but with a ton of dialing in the machine and tooling.
    (2) 1100M mills and (1) Slant Pro lathe - Been running Tormach for about 6 years.
    The Body Armor Dude - Andrew
    Mar 2020
    218
    I'm running an 1100M. I have some experience on a PCNC440 as well which was giving me +/- .01" consistently but take that with a grain of salt because I had NEVER run a mill or a cnc prior to operating that machine so I'm confident my own mistakes were leading to bad parts. Hell, it took me 2 months of saturdays before I was able to make a single part start to finish without crashing something along the way and smacking the e-stop.
    Nov 2012
    591
    I would say +/- .005" is conservative, when I'm "just doing it" I'm usually within 0.003" unless my file is dumb (pushes thin things too hard and getting deflection and such.)
    When I have something that really matters, I will walk it in, and get to about 0.001". It is rare that I need this -- it's mostly bores for pins or bearing seats.
    This is on Series 3 1100 and more modern PCNC 440.
    Apr 2013
    1788
    I agree with your general accuracy comments but I don't think that a Tormach is capable of *milling* a bore for a bearing seat. The problem is both dimensions and roundness. For bearing seats I use an Erickson TenthSet boring head and can dial it in to be round plus within a few tenths of the desired size. For small bearings it may be better to use a reamer.
    Jun 2018
    84
    I have a 1100M that I have had for 3 months. I'm still learning it's capabilities but so far I'm impressed with Path Pilot and the machine's accuracy. I ran an aluminum contour job today that didn't require extreme accuracy. I grabbed a used 1/4" 2 flute HSS end mill, installed it in a ER-16 collet and holder and started cutting. RPM was 5000, DOC was .500", WOC was .025", and the feed rate was 25 IPM. The final dimensions were within .001" in X and spot on in Y. I've got two more parts to run tomorrow. I'll report back if the dimensions vary more than .0005".
    Hope this is useful info.
    Mar 2009
    1863
    I can do +/-.001 work all day long on my series II 1100.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Mar 2009
    1863
    Quote Originally Posted by pastaman View Post
    I’m still using Mach III. I’ve seen too many things Path Pilot won’t do.
    Apr 2013
    1788
    Quote Originally Posted by Steve Seebold View Post
    Is that accuracy working from the print or after tweaking things?
    Apr 2013
    1788
    Details please of missing capabilities in PP? I used Mach3 for several years but find PP much more capable and I am not missing anything that I had in Mach3.
    Jun 2018
    84
    Quote Originally Posted by kstrauss View Post
    +1
    Jun 2018
    84
    I ran the remaining two parts today (Parts B and C). Again I didn't take any precautions like creeping up on the final size or change speeds and feeds. I used the same parameters as the first part (Part A, see my post above). Here are the measured dimensions in X and Y:
    Part A
    X dimension - 5.2510
    Y dimension - 4.9990
    Part B
    X dimension - 5.2505
    Y dimension - 4.9994
    Part C
    X dimension - 5.2500
    Y dimension - 4.9992
    These dimensions are representative of my machine. My model is setup for 5.250 in X and 5.000 in Y. Pictures attached. As Steve said +/- .001" is achievable.
    I'm new to this , I have a 770m And a 440 due in next week .
    In anealed 4140 once I got the finish passes dialed in plus or minus .001 has been relatively easy to maintain .
    Before I got the finish strategy figured out for my parts plus or minus .003 was no harder to achieve then tying my shoes .
    Nov 2013
    402
    I can hold +/- .003 easily on my 770.
    +/- .001 requires a little finesse.
  1. Average Costs?
    By mercury049 in forum Want To Buy...Need help!
    Last Post: 04-13-2016, 01:34 AM
  2. Average of curves
    By sdantonio in forum Rhino 3D
    Last Post: 04-04-2010, 02:12 AM
  3. Machining for the Average Joe
    By abomb55076 in forum DIY CNC Router Table Machines
    Last Post: 03-25-2009, 11:02 PM
  4. Is this an average X2 price or will it go down?
    By idtkid in forum Benchtop Machines
    Last Post: 02-13-2009, 06:12 AM
  5. 1/4-20 average speeds?
    By ShayArnett in forum DIY CNC Router Table Machines
    Last Post: 12-24-2004, 08:17 AM
