585,967 active members*
4,449 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Jun 2014
    1780
    Re: 660 u shars vise on my 1100 s3
    Quote Originally Posted by mountaindew View Post
    My Tormach machinist vise requires regular cleaning to work correctly. Also careful adjustment after cleaning or I get some Jaw lift. I have read about people locking their vise or vises down in same location for months. My vise would get rough or unusable if I did that.
    Mine is always mounted to the table, I use an oil mix for coolant so no rust under it etc. To clean it I just use the coolant line and a brush to wash out the chips that collect in it.
    mike sr
  2. #22
    Quote Originally Posted by popspipes View Post
    This is the first vise I have had trouble with, I thought about the valve grinding compound but a bit apprehensive as to how to get rid of the grit once the job is done??
    I think you would have to do a complete tear down and thorough cleaning, but it would fix the issue if done correctly.
  3. #23
    Jun 2014
    1780
    It is a possibility Terry but when its cleaned out with the wire brush it works fine, no dings in the shaft that I can tell, I wont be spending 167 dollars for a tap either! The thread milling has piqued my interest as I have never tried it, I was thinking to make something on the lathe, the last time I made a left hand thread was 45 years ago, I may be a bit rusty ha!!
    I managed to cut a 1.0625 (I think) x 7 thread split adjustable homemade L.H. tap of sorts, gave it a quick case harden in some kase-nit. It did the job after about 50 passes thru the vise nut with my trusty Milwaukee drill motor. I dont think it cut much of anything but I adjusted the screw to tighten the tap until I had an even resistance thru the whole length of the nut. I dont think it cut much of anything but rather lapped it in, result is it worked.<br>
    Hopefully this will work long term.
    mike sr
  4. #24
    Apr 2011
    720
    Great to hear you got it whipped! Nice looking tap too.
    Terry
  5. #25
    Jun 2014
    1780
    Thanks Terry!
    I think it acted more as a burnisher than a tap ha! Regardless it got the job done.
    mike sr
  6. #26
    Mar 2009
    1863
    Quote Originally Posted by MFchief View Post
    Terry
    I have solved my vise problems. I found 2 6 inch QUAD 1 vises and grabbed them.
    These vises are great because the fixed jaw is in the front of the vise and the back jaw moves which allows me to work in X plus Y plus coordinates instead of X plus Y minus.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
Page 2 of 2 12
  1. Replies: 0
    Last Post: 09-22-2015, 07:39 PM
  2. Shars 400DS double vise, any comments?
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 09-13-2014, 06:55 PM
  3. Shars 6" reverse vise keys for Tormach
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 06-12-2014, 05:22 PM
  4. Shars 440V Vise, accuracy and table keys.
    By Kingjamez in forum Benchtop Machines
    Last Post: 09-28-2010, 12:41 AM
  5. Tormach + New Shars Vise ....
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 04-29-2010, 07:11 PM
