585,886 active members*
6,321 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Jun 2014
    1780
    660 u shars vise on my 1100 s3
    I have a 660 u shars vise, (Kurt knockoff) I believe, the screw is tight at spots in the vise nut, does anyone know if a tap is available to clean the threads in the vise nut? I called shars and they dont have or sell a tap for this purpose (1.0625 x 7 tpi), I think this may be an OEM tap.
    I can clean it up with a rotary wire brush, this will work for a period of time, then it will start to get tight spots in it again over a few months time.
    I would like any advise on any method that would fix this problem .
    thanks in advance!
    mike sr
    Mar 2020
    218
    Re: 660 u shars vise on my 1100 s3
    Sounds like you're getting chips or fines built up in the nut. The wire brush is probably cleaning it out and/or smoothing any burrs caused by those chips getting jammed into the nut when you work the vise open and closed. Running a tap through it may open the threads up more and give you some additional clearance but wouldn't really solve the problem.
    Apr 2011
    720
    Mike, assuming the problem doesn't always occur at the same spot on the threaded shaft, it sounds like your best option might be to buy a new nut if they sell them.
    There is a universal internal thread repair tool out there, but I have not used it and so have no idea if it works worth a hoot. It's also pretty pricey, $118 in the size you would need.
    Here's as link to it on amazon if you're curious.
    Terry
    https://www.amazon.com/Universal-Int...00D8WJ5S0?th=1
    Jun 2014
    1780
    Thanks guys, I just had everything disassembled on it, there were a few fines in the nut, everything else looked perfect, I reinstalled one of the wipers as it had came apart, I have this problem about once a year, this is the third time I have had it apart for the same thing, binding around 3 to 4 inches open, I can still turn the handle but it takes some of effort. It looks to be 1.0625 x 7 tpi left hand thread, those taps appear to be scarce, I havent found one yet. I called shars and asked about the 10 year warranty, needless to say it doent cover the problem I am having. I will look up the thread repair gismo Terry, thanks for the info. I have an old Bridgeport vise, machine dates to 1952 and it hasnt had problem one.
    A new nut is 40 dollars on the website plus shipping.
    Kurt has a tap rental for such problems, Shars doesnt..........
    I am so busy in retirement I dont know how I had time to work a few years ago ha!!
    Thanks for the replies.........
    mike sr
    Apr 2013
    1788
    Have you considered that perhaps it is a standard metric screw? 1.0625" is rather close to 27mm (actually 1.06299"). The standard pitch for 27mm is 3mm or 8.47 tpi. For Acme form threads the standard is M28x3 rather than M27x3. Just a possibility...
    Jun 2014
    1780
    Quote Originally Posted by kstrauss View Post
    I checked it just now with a thread pitch gage and it is 7 tpi.
    It works well now, I drilled and tapped the nut 1/4-28 for a grease zerk, it will work fine for awhile, just kind of irritating, it never locks up to where I cant turni it.
    mike sr
    Apr 2011
    720
    Mike, I laughed when I read your comment about being busy in retirement. I've said many times to my friends who are still working that I'm busier now then before retirement, but they all look at me like I have a screw loose! LoL
    Jun 2014
    1780
    Quote Originally Posted by MFchief View Post
    An old friend told me that years ago and I thought what is he talking about?? I now understand..........
    Sure wish I had a tap for that vise, I am thinking maybe make one out of drill rod or something, to just chase the threads?
    I sometimes wonder if I have too much time to think??
    mike sr
    Apr 2011
    720
    When I looked at your vise on shar's website, I saw that they provided an STP file so I downloaded it to see if I could pick out any info about the thread.
    But, they conveniently left out the screw and the nut from the file. Almost as if they don't want anyone to know the details about it.
    Terry
    Jan 2016
    99
    It could be metric size shaft with inch pitch thread. We have a couple DoAll lathes at work (actually Harrisons).
    When fixing the cross slide and compounds, I needed to replace the screws due to wear. Metric shaft with inch pitch. I ended up ordering precision acme threaded shafts and making new nuts to fit.
    Dave
    Jun 2014
    1780
    since the wire brushing its working fine, still a bit snug in the area in question, it acts like it was tapped a bit undersize or the screw is a bit oversize, or maybe a green casting, who knows..... a new nut is 40 dollars plus freight, I may do that if the problem persists.
    mike sr
    Jun 2014
    1780
    1.125 x 7tpi LH, just got a reply to my query from Shars.
    mike sr
    Apr 2011
    720
    I didn't do any searching for best price, but the first place I googled for that sized tap was $167. Yikes!
    Seriously though, Are you positive the trouble is in the nut and not the shaft? If it gets sticky at about the same distance each time, it makes me think the shaft may have a small ding, or be slightly bent at that spot.
    Terry
    Nov 2012
    591
    Thread milling is a fantastic invention for those "once in a blue moon" thread forms!
    Jun 2014
    1780
    Terry
    It is a possibility Terry but when its cleaned out with the wire brush it works fine, no dings in the shaft that I can tell, I wont be spending 167 dollars for a tap either! The thread milling has piqued my interest as I have never tried it, I was thinking to make something on the lathe, the last time I made a left hand thread was 45 years ago, I may be a bit rusty ha!!
    mike sr
    Nov 2007
    2151
    Quote Originally Posted by popspipes View Post
    My Tormach machinist vise requires regular cleaning to work correctly. Also careful adjustment after cleaning or I get some Jaw lift. I have read about people locking their vise or vises down in same location for months. My vise would get rough or unusable if I did that.
    Jun 2014
    1780
    Quote Originally Posted by mountaindew View Post
    Mine is always mounted to the table, I use an oil mix for coolant so no rust under it etc. To clean it I just use the coolant line and a brush to wash out the chips that collect in it.
    mike sr
    Jun 2014
    1780
    I managed to cut a 1.0625 (I think) x 7 thread split adjustable homemade L.H. tap of sorts, gave it a quick case harden in some kase-nit. It did the job after about 50 passes thru the vise nut with my trusty Milwaukee drill motor. I dont think it cut much of anything but I adjusted the screw to tighten the tap until I had an even resistance thru the whole length of the nut. I dont think it cut much of anything but rather lapped it in, result is it worked.<br>
    Hopefully this will work long term.
    mike sr
    Apr 2011
    720
    I agree, just did that a couple of weeks ago making a new part for a pressure washer pump manifold. The thread was 3/8-18 npt but the stock could only be .65" instead of .675". Thread milled fine.
    But Mike's situation is a bit tougher, picking up an internal thread in the nut would be hard, and making a new vise nut evener harder, at least for me.
    Terry
    Apr 2011
    720
    Another thought, should be possible to thread mill a tap to use on the nut.
    Terry
Page 1 of 2 12
  1. Replies: 0
    Last Post: 09-22-2015, 07:39 PM
  2. Shars 400DS double vise, any comments?
    By LRF in forum Tormach Personal CNC Mill
    Last Post: 09-13-2014, 06:55 PM
  3. Shars 6" reverse vise keys for Tormach
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 06-12-2014, 05:22 PM
  4. Shars 440V Vise, accuracy and table keys.
    By Kingjamez in forum Benchtop Machines
    Last Post: 09-28-2010, 12:41 AM
  5. Tormach + New Shars Vise ....
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 04-29-2010, 07:11 PM
