585,931 active members*
5,100 visitors online*
Results 1 to 8 of 8
    May 2006
    309
    Alternative to Taig mill?
    Are there other cnc-mills that are a little bit bigger than Taig and at nearly the same price level?
    Apr 2018
    88
    Re: Alternative to Taig mill?
    Hello,
    Taig mill is tiny. Save some more money and get a BF20. You will be way more happy
    May 2005
    1662
    Something ready to run ?
    There's not much in the small and inexpensive turnkey cnc market. I've seen stuff on AliExpress if you're feeling brave.
    May 2006
    309
    Sorry, double post.
    May 2006
    309
    Hello,
    Can that machine be run with nema 23 steppers and Gecko G540 driver, and can it be bought with ball screws?
    Jan 2013
    630
    If I thought I could figure how to get it to Norway I'd make you a good deal on a BF20L that is already converted with the PC, Mach Standard Mill license, a double 4 inch vise, TTS tooling and clamp kit.
    May 2005
    1662
    Quote Originally Posted by jaru-eri View Post
    Hello,
    I'm not sure what the differences are between a BF20 and a G0704, I think the G0704 is a variant or clone ?? Ball screw kits are available for the G0704 and most builds I've seen use DIY kits.
    Complete cnc machine ---->https://www.automationtechnologiesin...-kit/g0704cnc/
    Kit ---> https://www.automationtechnologiesin...duf-ballscrew/
    How interchangeable parts are between these machines someone else may know.
    The Taig is light weight but it has a decent work envelope and a fast spindle. It's also low priced and ready to run. If your work is light duty it may do all you need. Be aware the table is very narrow.
    Btw last post I meant to say Alibaba not AlliExpress.
    Apr 2018
    88
    BF20 is the same as G0704 but with some castings differences.
    But you would want the BF20L version that has longer X travel.
    Conversion wise there are many CNC kits available. In europe there is the DamenCNC website that sells such kits.
    Or you can go the Hoss way and make the 2 step conversion yourself. If you can do some machining then this would make for a nice project
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. Looking for alternative software to cncmasters supra mill
    By ChrisW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2014, 03:51 AM
  3. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  4. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  5. My BF-200 is hear! Quality alternative to X2 or X3 Mill.
    By samim in forum Benchtop Machines
    Last Post: 07-21-2007, 03:48 AM
